Question about Exercise & Fitness
Nordictrack a2050 beeps and dashboard lights up but does not run. Detects heart rate on grab bar but belt does not turn or elevate.
My name is zanaya
Posted on Oct 20, 2013
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Posted on Sep 20, 2012
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Tunturi c60 crosstrainer no longer picks up heart rate from belt and only intermittently from bar sensors any advice would be welcome.
follow this steps and fix it. God bless you
1) Reset /Off switch after 5 minutes if the the same had been tripped
2 Leave the safety key in the console, if the elevation is not adjusting or not change during Ifit, or videos are playing. Press the buttons for incline motor and pull out the safety key, while incline is moving. Re-insert again the Key after few seconds.
3 Turn the adjustment bolts on bottom rear by 1/4 counterclockwise, with allen tools.Tes the belt pulling up in each side. Lifting the belt 3 to 4 inches off the treadmill indicates a proper tension. Repeat the adjustment in case if necessary. 4 Wipe down the heart rate sensor. if not produce any accurate reading. Dry the sensor and try again
Sep 23, 2013 | Exercise & Fitness
Nordictrack c2500 treadmill troubleshooting
you must tight the ribbon cable and clean it. 2) clean the keypads from dirty, corrosion, and oxide. 3) adjust the REED switch see the diagram attached, clean it, and tight the connector very well.
Jul 21, 2013 | Exercise & Fitness
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
God bless you
Sep 19, 2012 | Nordic Track NordicTrack Elite zi...
How do you reset heart sensor?
1 Reset /Off switch after 5 minutes if the the same had been tripped
Nov 19, 2011 | Nordic Track NordicTrack T5 zi Treadmill
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    When i power my Nordic Trac A2050 on it powers up but when I press the speed button or incline button is beeps twice but does not reponse to the command
    This sounds like a bad controller. If the machine is under warranty contact the warranty provider. The controller is not hard to replace if you are electrically inclined but it does require calibrating.
    Jun 14, 2010 | Nordic Track NordicTrack Treadmill, A2550
    NordicTrack A2105 console is very faint to read
    It sounds like the upper console has a loose connection ( check wire harness connections in the upper and lower board section ) or the upper console is failing call Icon Fitness @ 1-800-999-3756
    Jun 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
    Nordictrack Model A2550: Incline function!!??
    this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
    Feb 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
    Exercise & Fitness Logo
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
