Question about Philips 26PW6341 26" TV
Keeps powering off
Any ideas. Just keeps switching off - stays on for a little while then powers off to standby mode !!!
  • Guiseppe Oct 01, 2007
    How do I correct it - is it a case of finding a repair centre somewhere & it's a common problem ???
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is a power supply failure in your tv. it is not major problem. can be ractified without taking much time. good luck
Posted on Sep 27, 2007
How do I fix
Hi Mick
Not Enough Info to Fix
If it won't turn on try Leaving off for awhile. At The wall.
If still the same then it's probably the switch mode Power Supply Module refusing to supply power to the Main Board.
Switch mode PS break down because of heat and Leake electrolytic Capacitors internally.
Mar 06, 2015 | Televison & Video
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
Has power but keeps switching to standby
Disconnect all speakers at the receiver and turn it back on, if it stays on post a comment and I will help you troubleshoot further. If it still cuts out, it needs to go to service for repair. Hope this helps.
Aug 21, 2009 | Denon AVR-1907 Receiver
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Standby power switch
If you are concerned about humidity and switches, spray them with DeOxit. You can get it at Radio Shack.
Jul 12, 2007 | Yamaha AX-596 Amplifier
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Philips 26PW6341 26" TV Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
