Question about Hasselblad PCP 80 Slide Projector
I have three Hasselblad PCP 80 slide projectors not used for the past four years; kept in their transport cases, not knocked about and in a dry store. Now, all of them have the same problem: the "Unlocked/High Temp" red light stays on. I have checked that the magazines are locked on. When the "Lamp On" button is held down, everything works (except the red light stays on). Any ideas?
3 Suggested Answers
SOURCE: I have an occasional problem
From my PCP80 Service Manual:
FAULT: The projection lamp is lit for a short moment and then goes out. POSSIBLE CAUSE: 1.The rectifier and lamp change board are out of order. AND/OR: 2.Both triacs turn on. Both lamps are lighted until the automatic circuit breaker is released. MEASURES: 1. Change both boards. 2. Change the triac board.
See Also:
FAULT: The projection lamp does not light. POSSIBLE CAUSE: The automatic circuit breaker has released. MEASURE: Reset the circuit breaker. AND/OR: Fuse F102 has blown. MEASURE: Change the fuse. AND/OR: The rectifier and lamp change board are out of order. MEASURE: Change both boards. AND/OR: The triac board is out of order. MEASURE: Change the board.
Posted on Jan 10, 2011
SOURCE: where may I get a circuit diagram of the Hasselblad PCP 80 from 1992
you ****
Posted on Mar 12, 2008
Will slides back from 1960 work in a Kodak Carousel Slide Projector?
As long as the slide film is in 2"x2" mounts, yes! I would advise you to use an 80-slide tray as opposed to a 140-slide tray. The individual slide compartments in an 80-slide tray are wider, making it more forgiving to older, possibly warped slides. 80-slide trays can still be purchased from: www.vinevalleyimaging.com. Good Luck! Jim
Jan 16, 2013 | Kodak Carousel 4600 Slide Projector
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
I have an occasional problem with my Hasselblad PCP80 projector. Shortly after switching on the lamp will go out for no apparent reason, but all other controls on the projector work okay. The high...
See Also:
Dec 21, 2010 | Hasselblad PCP 80 Slide Projector
I have an old Kodak 760 carousel projector with 140 slide rotary. Can I get replacement rotary slide holders?
You can buy new & used Slide Trays for Kodak Slide Projectors from: www.vinevalleyimaging.com They have amazing connections with slide projector users!!
Oct 15, 2010 | Kodak BC-4401 Slide Projector
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Feb 24, 2010 | Kodak Office Equipment & Supplies
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
Hasselblad PCP 80 Slide Projector Logo
60 people viewed this question
Top Hasselblad Office Equipment & Supplies Experts
k24674
Are you a Hasselblad Office Equipment and Supply Expert? Answer questions, earn points and help others
