I have a Toshiba satellite c855d - S5303. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the battery. The white light will go off if I unplug it. its almost like the on off switch is not working.
map9966
  • 2351 Answers
SOURCE: packard bell imedia 3034
After reading a ton of posts you may be correct, your board is dying or is dead.
An easy way to get your data off your old Hd to your new Hd would be to connect it directly into the new PC internally.
Just like you would a new drive only you would set the old drive as a slave. Here is your 3034 link.
http://support.packardbell.com/uk/item/index.php?pn=P842025601&g=1400
The motherboard in this 3034 is Gigabyte, GA-8SIML-NF7, shown at this link: http://support.packardbell.com/uk/item/index.php?i=spec_columbia5p&ppn=P842025601
There is almost no chance of you finding this board its just too old. There are boards at this link that will handel all of your imedia 3034 parts, motherboards.
http://computers.pricegrabber.com/motherboards/p/40/form_keyword=motherboards+478+socket/rd=1/mode=g_us_b_s/skd=1
Hope this helps you Jim!
Please vote...
Posted on Jan 19, 2008
SOURCE: Orange Light permanently on motherboard. PC won't start
Good Day.
I'm experiencing orange light on motherboard and my PC"Dell" wont start anymore.
May i know what is the solution to resolve the problem on this?
it was just turned off accidentally while i was still on my work.
Your answer on this is greatly appreciated.
Thanks.
Mac Mundale
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Posted on Feb 04, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Satellite A200 Not Charging battery
You're gonna have to replace the motherboard.
Check to see if it's under warranty through your motherboard manufacturer's website.
Most of them are covered for 3 years.
Best of luck!
Posted on Feb 24, 2009
SOURCE: toshiba M400 tablet wont start
I've had this problem intermittently on my Toshiba M400, and it recently became bad enough that it was failing to start on most attempts, and crashing soon afterwards if I moved it. Prodding the heatsink to change its position may have helped, but this could have been due to chance. It also had a habit of resetting itself when leaning on the left side of the keyboard when typing, but not when using an external keyboard. It's always had occasional crashes under high CPU load, causing the machine to freeze and the fan to go up to maximum. BIOS updates improved this initially, but in recent months it got worse again, especially when using Virtual PC unless hardware virtualisation was disabled.
I've just stripped down the laptop using the guide suggested by thiscomputer at http://www.irisvista.com/tech/laptops/Toshiba-Portege-M400/take-apart-tablet-pc-1.htm (good find!). Many parts are more fragile than in a desktop PC, but otherwise if you're used to taking stuff apart it shouldn't be that big a deal. You'll need a normal and small crosshead screwdriver (jeweller's screwdriver set works fine) and space to lay out the screws in a pattern so you remember where they go - consider making notes.
I fixed two things that could have been a problem: Firstly, a fair amount of dust was blown away with a hairdryer and vacuumed from the heatsink. Secondly, the pink thermal grease that couples the CPU to the copper heat pipe appeared to have all squeezed off the CPU die and had accumulated around the sides, possibly due to the small freedom of movement in the heatsink being repeatedly shaken. The grease was still soft so could be scooped back onto the die with a flat-bladed screwdriver. I also bent the legs of the Y-shaped CPU-to-heatsink retaining clip so that there was a greater downward force on the CPU. I figured this would improve thermal contact, especially if the clip had naturally bent and come loose over time. Removing the CPU itself didn't show any damage, but might have improved the electrical contact when reinserted. Be careful when screwing the Y-shaped retainer back in - because of the springy nature of the legs, if the screwdriver slips the screw will fly across the room and you'll have to hunt for it :-) The other thing to note when reassembling is that the wi-fi on-off switch engages with the lug on the motherboard, if this is wrong you won't be able to move the switch and the actual state will be the opposite of the switch position.
Finally, after I reassembled it still refused to start. I noticed the DVD drive wasn't properly flush with the case, and on removing the DVD drive it started. Close inspection of the drive and laptop connectors revealed a small metal tab had come loose, and the laptop continued to work with this tab removed and the drive reinserted properly. I removed and swapped some memory modules while experimenting with the DVD drive which also had some effect - it's possible that an ill-fitting DVD drive bends the memory above it and affects the contact. It's entirely possible that this was the only problem to begin with, and that playing with the CPU made no difference, so maybe check this first! But whatever it was, happily my m400 seems to be operational again.
Posted on Apr 11, 2009
TOSHIBA SATELLITE C55D POWER LED ON WHEN CLICK POWER . ,BUTTON SCREEN LIGHTS UP AND SAYS BATTERY LOW AND CHARGING
Yep... classic signs of a bad/poor battery! About $13 including US shipping (US Seller too).
See eBay: 322759285844
If you REALLY want to do a good job buy a NEW POWER SUPPLY TOO! They do age ~ with time ~ like all of us.
$9.78 shipped.
Happy BATTERY with it's NEW Power Supply!
Anthony
Lot Battery for Toshiba Satellite C55 C55D C850 C855 C850D C855D PA5024U...
AC Adapter Power Supply Cord for Toshiba Satellite C55D A5120 L755D S5150...
Nov 21, 2017 | Toshiba Computers & Internet
I have Satellite C855d which promos for password at start up.. No clue what the password is or how it got there how do I by pass this?
The password is required when Win8 is set up as a default. The person who installed or completed the installation of Win8 will be the person to ask.
Oct 17, 2014 | Toshiba Satellite Computers & Internet
Stuck on toshiba logo screen.
Dear Branden,
Please remove the battery and wait for 30 sec, after that insert the battery back and turn on the machine
Regards,
Samy
Aug 10, 2014 | Toshiba SatelliteR C855D-S5900 Laptop...
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
Does my toshiba satellite c855d have hdmi output
Hi Alex,
The Toshiba C855D-S5320 does. Can you confirm the type of C855D you have. With the description of the plate I doubt your model does. On the one I use, I knowingly gave up touch screen for HDMI with budget I had. I have it connected to a 24" ASUS screen and I'm very happy with HDMI. Good luck! Toshiba C855D S5320 Laptop
Jan 06, 2013 | Toshiba Computers & Internet
Is there a cover over the hdmi port on the toshiba C855D-S5359
According to Toshiba Website - there is no HDMI port on this model laptop.
http://us.toshiba.com/computers/laptops/satellite/C850/C855D-S5359/
Dec 30, 2012 | Toshiba Computers & Internet
Screen went black while using laptop, have rebooted, goes black 1 sec after starting up
i have the same problem with my Satellite A135-S2256, starts up all lights light up except processor light, fan turns on but CD/DVD drive wont turn on : ( any ideas on why? how to fix?
Thank You
Oct 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
