Question about Pride Health & Beauty
Gogo elite scooter it runs fine for about20 min then starts bleeping (7 bleeps)??8
Load test batterys 1 or both no good
Posted on Oct 21, 2013
3 Suggested Answers
  • 177 Answers
SOURCE: 7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
  • 46 Answers
SOURCE: I have a gogo scooter it bleeps once than cuts out
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Posted on Jul 11, 2010
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
Why does it constantly beep?
hi, it's it's running okay but bleeping , could be low battery voltage or a failure in the bleeping circuit with wiring or the controller...
Regards
Rob
www.gewzirepairs.co.uk
May 03, 2014 | Pride Mobility Products GoGo Elite...
Beeps 7 or 8 times and stalls. turn key off and back on and it runs
hi, 7 bleeps is the throttle pot , most likely it is worn, or miscalculated...depending on model , the newer one's use a self contained unit so no calibration is required however will fail when the voltage gets too low,,, , I suggest you check the connections to the controller as they can be a source of problems...from the throttle to the controller....
Regards
www.gewizrepairs.co.uk?fixya
Oct 08, 2013 | Pride Mobility Products Go-Go Elite...
GoGo Elite 4 wheel scooter - appears to be fully charged but when you try to go forward it goes a foot then stops. I get 2 beeps. It will go in reverse with no problem. If I am not sitting in it you can...
How old is the scooter? 2 Bleeps indicates low battery voltage, and such, require replacement. When you are in reverse, the current draw is a lot less than when going forward, just like not being sat on the scooter too. As soon as any real load is applied to the scooter, the power will drop down below 16v and will cause a controller trip (2 bleeps)
However, this could also be caused by bad battery connections, either inside the battery box, or where the contacts meet on the bottom of the pack - onto the chassis. Check for discoloured pins / connections.
Sep 23, 2013 | Pride Health & Beauty
9 beeps gogo elite traveler
hi, 9 bleeps on a go go mean a parking brake fault or motor connection problem , now it could just a be case of a poor connecting however go you confirm the exact controller used ?
Check the brake connections and motor cable connections making sure they are clean and tight.
Regards
Mar 09, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
On the dalton p376 power wheelchair,the controller is running through the led lights 7 full times and 25% of the way the 8th time.the controle panel also beeps after the 8 th time.I followed all...
It sounds like it could be locked. Try pressing and holding the power button until it bleeps. then move the joystick to the forward position and hold until it bleeps. Then move the joystick to the reverse position until it bleeps. turn off and then back on.
Check your manual for locking/unlocking. Hope it works
Sep 15, 2009 | Electric Mobility Shoprider Electric Power...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
