Question about Frigidaire GLEF378 Electric Kitchen Range
Electrolux Range temperature problem?
My family was baking a cheesecake at 350 degrees, when it caught fire. After we took it out, the stove started beeping continuously and it showed F10 on the screen. Anyone know what this means?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You need to replace the temp. probe. Here is the part to order.
Posted on Oct 21, 2013
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
jyackle5
  • 8197 Answers
SOURCE: Getting an error code F1 and F3
F1,F3,F9 codes mean.
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
Posted on Dec 16, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
Maytag317
  • 1136 Answers
SOURCE: Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Posted on Jun 24, 2009
SOURCE: My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Posted on Nov 18, 2009
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag oven overbakes or burns bottom of cookies, biscuits
Try this first, if the temperature is off contact me.
Put an oven thermometer at the center of the oven and set the oven to 350 degrees F.
Check the temperature indicated on the thermometer after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Apr 25, 2009 | Amana AER5515QA Electric Kitchen Range
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Stove keeps shutting off by itself
HI I have a different brand, but this same thing was happening to our oven, I had to have a repairman replace the temperature sensor in the oven. Apparently it was reading the temperature as like 300 degrees higher than it actually was so it was shutting off (I guess as a safety mechanism). Hope this helps. Good luck.
Feb 12, 2007 | Maytag MER4351A Electric Kitchen Range
Frigidaire GLEF378 Electric Kitchen Range Logo
98 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
