Question about Garden
Bar studs threads are stripped out on ms1432, 32cc McCulloch. Can they be replaced? If so, how do you do it and where do you get them?
    Sergeant:
  • 342 Answers
Wade there is a place called central Spares on the net. They do most parts and they may have a universal one.
Posted on Oct 20, 2013
SOURCE: chainsaw bar studs
empty out oil tank . you have to tap old stud out through oil tank.replace same way can be tricky but you should be able to get back in
Posted on Oct 22, 2008
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
  • 226 Answers
SOURCE: threaded stud that holds chain bar broke off, how do I get it off.
If it is broken off at the saw, you need to get an ez out to remove it - follow the instructions with it. pretty unusual for both studs to break off at the same time. Hope this helps you, Rick
Posted on Apr 25, 2009
dontbother10
  • 2220 Answers
SOURCE: Guide bar nut loose (stripped stud). How do I
I hope the nut is stripped and the stud is OK. Try to gently wedge something below the nut and with a socket attempt to slowly unscrew it.
Remington IPLs can be found here:
Remington.com
http://www.remingtonpowertools.com/find_manual.cgi
They do not use model names. Under "Products" click "Chain Saws"; find an image matching your model and click it. Some list a manual that includes an IPL some do not. If no IPL is listed the only place to get help is the "Repair Center" nearest you for parts. I doubt a bad stud can economically be replaced.
If the stud is still good NAPA Auto Parts can assist you to find a replacement nut. HTH
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington Mighty Mite gas engined chain saw . How
Was this saw manufactured in the 70s? If yes what are the odds anyone can help you? arboristsite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of chainsaw enthusiasts (free to join) that restore old saws. there is a thread that discusses your saw.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf
You might find some pointers here as well
If its mine and I'm serious about repairing I'd find a machine shop.
Lou
Posted on Sep 18, 2009
The threaded sleeves for the studs that hold the guide bar are stripped. What can I do to repair them?
remove bad studs with stud extractor and replace with new ones ?? or maybe normal bolts ?? (if in engine housing )
or in a bind ive even rethreaded them to fine thread (assuming course was old thread) with a die and used std fine nuts on them as well .
if studs go in plastic case/frame then case needs to be disassembled and then studs press out other direction
Mar 16, 2015 | Garden
How to change bar bolts on mcculloch ms1635 chainsaw
The only reason I can think of to replace the bar screws is if one stripped or was broken since the bar is held on by nuts. The screws are installed in the engine case. The best thing to do is take it to a service center.
However, if you really want to do this, replacing part # 00083856-00 (JFT # 9214-310001) is not trivial. You will need to strip the housing off the saw to access the back side of the case. Once exposed the screw (bolt) can be turned out and a new one installed. After which, of course, you get to reassemble the housing.
Oct 13, 2014 | McCulloch Garden
Mcculloch chain saw bar studs broken
Well, they'll need to be replaced.
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Mar 20, 2012 | McCulloch Garden
How do I replace a broken chain bar locating pin/bolt on a McCulloch 540e petrol chainsaw?
The bar bolt is a stepped stun, it is screwed into the bar pad, you will have to grap it with a suitable pair of grips and undo it like a srew ( right hand thread, counter clockwise as you look at it ) you can then replace it with a new stud.
Feb 05, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do I replace one of the bar studs that is stripped?
This can be a DIY project but I'm go to suggest you contact a local saw shop or 2. They will usually do it for less money ($10-20) then you can buy the tools and supplies and are experienced with the procedure. GL
Lou
Oct 17, 2009 | McCulloch Garden
Remington Mighty Mite gas engined chain saw . How can I replace the stud for the guide bar ? The stud is stripped and I have attempted to unscrew it without success using vice grips. It turns but appears...
Lou
Sep 18, 2009 | Remington Garden
Lug stud
Here's another thought - if the stud isn't too badly stripped, you may be able to use a re-threading die to restore the threads. The thread type and size will depned on the make and model of your car. An autmotive parts store can usually help with this.
If you must replace the stud,
A bad stud can usually be driven out through the back of the axle flange. You said the stud was stripped. You can:
Force one of the lug nuts onto the stripped stud maybe two to three turns , then take a drift pin and drive the stud out the back. The stud will have grooves that hold it in place on the axle flange. You willl hhave to hold the stud head with vice grips and remove the lug nut to get the stud out.
To install a new stud, insert it from the back, add a little grease to the knurls (grooves) and pull it into place with a lug nut. The stud must be firmly seated in the axle flange.
Mar 28, 2009 | 1998 Pontiac Trans
Stripped bolts
sounds like the bar stud is stripped out in the case. you might have to have a thread insert, like a Heli-coil, put in.
Mar 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Stripped bar stud
Dec 20, 2008 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
