Question about Gateway NV57H94u Core i5-2450M Dual-Core 2.5GHz 4GB 500GB DVD Rw 15.6" Led Notebook W7HP w/HD Webcam & 6-Cell Blue
Setup disk I must replace my hard drive and I do not have the initial installation disc. What can I do?
    New Friend:
Hi
You need to:
1. Create recovery disk (link)
2. Replace the hard drive
3. Restore using the disk created (link)
Regards.
Posted on Oct 20, 2013
Hp nc8000 laptop. Installing used hard drive. Laptop doesn't recognize hard drive when installingXP Pro with disc. Recognized in bios. With install disc only sees previous opsys partition.
Verify that all previous data, partitions, format version etc.... has been removed. If this is a used hard drive it would be advised to erase and clean the drive before use. This can be done with various disk tools or boot disks and/or various open source software products. This is usually a user preferance when using tools of this type. Once the disk has been cleaned and initialized it should be ready for the Windows installation.
If after cleaned and initialized the disk does not show under windows the it could be no good!!!
May 13, 2011 | HP NC8000: NC8000 Pentium M 1.7GHZ, 512MB...
Can't install external hard drive. Do not have disc or manual. When I connect drive to USB port, drive lights up and makes sounds, but does not show new hardware.
Most likely the drive hasn't been initialized. Go to start, right click my computer, then manage. Select disk management on the right column. A window should immediately pop up saying disk initialize wizard. Press next, and it will guide you through on how to initialize the disk. Make sure you format it as well, so that the computer will recognize it as a drive.
Dec 29, 2009 | Maxtor OneTouch III Mini Edition 120GB...
HOW CAN I RESTORE MY ACER TRAVELMATE 2200 without the original disk??????????????? NOW CAN U ANSWER THAT...ASAP
Hello !
Note: the recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook.
You can try ALT+F10 or CTRL+F10 during the initial boot cycle. This should prompt the laptop to access the recovery partition on the hard drive.
If it doesn't work :
Activate BIOS Setup Utility, press <F2> during POST.
Check the BIOS settings.
a Check to see if "Acer disc-to-disc" function is enabled or not.
b Make sure the [Acer D2D Recovery] setting in [Main] is
[Enabled].
c Exit the BIOS Setup Utility and save changes. The system will
reboot.
Hope this helps.
Sep 29, 2009 | Acer Travelmate 2200 Notebook
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
My acer 5100 is not seeing my new hardrive
ur hardrive might not be fit properly in the slot or any wire could be loose.
Sep 01, 2009 | Acer Aspire 5100 Notebook
Setup does not detect any hard drives
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 10, 2009 | Dell Inspiron 2200 Notebook
Hard drive failed - replaced 60GB with 250 GB M35X can't format
Does your BIOS recognize the new hard drive?
Are you reinstalling from a Toshiba recovery disk or an operating system disk?
Additionally, there is a setting in the BIOS to turn on or off ACPI function for the hard drive. Find this in the BIOS, change it, and try reinstalling again.
When it works, be sure to change it back after installation.
Good luck.
tony
Jan 30, 2009 | Toshiba Satellite M35X-S109 Notebook
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
Gateway NV57H94u Core i5-2450M Dual-Core 2.5GHz 4GB 500GB DVD Rw 15.6" Led Notebook W7HP w/HD Webcam & 6-Cell Blue Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
