Question about Revo America Indoor/Outdoor Night Vision Bullet Security Camera RJ12, RBULRJCAM
How to set up a RJ12/BNC Type Camera - Revo America Indoor/Outdoor Night Vision Bullet Security Camera RJ12, RBULRJCAM
2 Suggested Answers
SOURCE: is there an adapter to go from rj12 to bnc
http://www.securitall.com/RJ-to-BNC-Coupler-P17.aspx
Posted on Jan 03, 2010
Wiring diagram for swann pro 642 camera
I don't know what you are doing with cat5 cable, according to the Swann Pro-642 manual
http://www.swann.com/downloads/product/2187M642CAM270212E.pdf
this camera uses a BNC connector on a RG-58 co-axial cable.
Installing BNC Connectors
Feb 23, 2017 | SWANN Home Security
I need a wiring diagram for soc-n120 camera
1 2 3 4 5 6 Green Red Yellow Bare Gorund Clear
Cover
Black RJ11e color & slot. Orientation Lock Pin Down. Wire at bottom
May 10, 2012 | Samsung Security Color Camera Soc-n120 +...
I need a converter that will allow me to hook up the rj12 cables to the coaxial connections on a 16 channel revo dvr
hi;
you wan to hook up coaxial to rj12 ,if you you do that the wire of rj12 has not to exceed 3 meters
cause camera signal (video) to become weak. Camera Video signal has to be fed only to coaxial cable, coaxial cable has an insulation to prevent interference.
so if you want to hook up be sure put a shielded wire.
thanks......hope this help.
Sep 03, 2011 | Revo America Indoor Dome Security Camera...
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
Dome camra wire connection with bnc
Preparation
Before installing your RCA camera scout the area and confirm that you will be able to run the cable from your surveillance digital video recorder (SDVR) to your camera. You may want to use RG59 Siamese cable, which is a single cable system with three wires: a coaxial cable for the video and a positive and negative wire to provide power to the camera. If you are installing your camera outside, place it at least 10 feet high to minimize tampering, or put your camera in a dome or other protective housing.
Coax Cable
BNC connector
BNC connectors and cable image by Albert Lozano from Fotolia.com
BNC connector
If you use Siamese cable to wire your RCA camera, you will run the cable first, and then install a BNC (bayonet Neill-Concelman--named for the inventors) connector on each end of the cable. BNC connectors vary by manufacture; install the BNC connectors according to the connector instructions. To get a general overview of the process, see the Resources section for a video on installing BNC connectors.
Power Wires
Plug with standard lamp-type cord
element electric power black image by Leonid Nyshko from Fotolia.com
Your camera came with a power supply with an integrated power wire; the power supply plugs into a standard wall outlet and the other end plugs into your camera. The cord is probably not long enough, in which case you will have to cut it and splice the Siamese in the middle to deliver power to your camera. The power supply wire is designed like a standard lamp cord and must be cut in half and split. One of the wires will be marked with a stripe, a series of dashes, a rib on the insulator or some other marking (just like a lamp cord). The marking indicates that this is the positive wire. After cutting the supply cord, connect the portion with the camera plug on it to the Siamese cable at your camera and then connect the power supply portion to the other end of the Siamese cable near your SDVR. The positive (marked) power supply wire should be connected to the red Siamese wire and the other wire connected to the black Siamese wire. While many people use wire nuts to connect the wires, connecting the wires with a wire beanie (see Resources) will provide a higher quality installation.
Plug-and-Play
Plug-and-play cables make it easier for homeowners to install their cameras. These cables incorporate all three wires into one cable system and come with connectors preinstalled so that you will not have to install connectors or cut wires. This is slightly more costly than assembling your own cable, but it will save you time and you will not have to purchase special tools to install the connectors. Run your plug-and-play cable and connect it by following the instructions which come with your cable. See the Resources section for a video on installing plug-and-play cables.
Dec 16, 2010 | Dome (8) Cctv Dome Color Ccd Night Vision...
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
Is there an adapter to go from rj12 to bnc
Dec 18, 2009 | Revo Home Security
Trying to hook up "back-up camera" which only has a coax output jack. Can I hook it directly into "ANT" jack or do I have to go through a demodulator and reduce to an RCA and then plug into V1 jack?
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Nov 25, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
How many instrument and power cables in one cctv
Hi a simple CCTV one camera system is 1 pair of power wires (1 positive 1 negative) and 1 piece of coax cable with BNC connectors at both ends. (usually rg59 but RG6 is better)
Things to be aware of:
Cameras come in both 12v DC OR 24Vac configurations some are capable of both but most models available to consumers run on 12v most professionals choose 24v models.
simple adapters used to convert from regular coax screw type connectors to either an RCA connector or BNC connector are available at Radio shack. If you need more than 1 or 2 its cheaper to get them on ebay.
You can connect a BNC equipped camera to an input on your TV by using one of these adapters. *put an RCA connector on the end and plug it into one of the yellow video inputs on the TV.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
Revo America Indoor/Outdoor Night Vision Bullet Security Camera RJ12, RBULRJCAM Logo
Top Revo Home Security Experts
Lawrence Oravetz
Are you a Revo Home Security Expert? Answer questions, earn points and help others
