Question about Craftsman 10" Table Saw
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed that the Arbor turns while I have the blade blocked so I can turn the nut....that doesn't seem right to me ???? could that be my problem?
    Problem Solver:
  • 6 Answers
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Posted on Nov 10, 2013
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
slave2aslave
  • 302 Answers
SOURCE: I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Posted on Oct 06, 2009
Testimonial: "thanks, I thought I was going to need to spend money for repairs. "
al_kupchella
  • 843 Answers
SOURCE: moter bogs down on my saw can anyonehelp
Maybe it's under-wired? When you start it up, if the lights dim, and the saw takes 2 or 3 seconds to come up to speed, then your wire is definitely too small and/or too long. 14 gage wire is almost always too light, although a very short 14 gage extension cord plugged into a circuit wired with 12 gage is OK. The cord on the saw itself is probably 14 gage.
Posted on Jan 29, 2010
radar001
  • 1051 Answers
SOURCE: Saw stopped working mid-cut as if power loss.
Could be the motor burned out. That shouln't happen and if it did craftsman is really good at replacing damaged tools. I'd return it for a replacement.
Posted on Mar 05, 2010
al_kupchella
  • 843 Answers
SOURCE: My saw problem has to do with changeing the blade.
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
Posted on May 17, 2010
When i turn on saw it bogs down and dose not take off spining but is not froz
If you are trying to rip wood with the fence it will most likely be that your fence is not true to your blade check the blade to see if it is the same distance on both ends of the blade to the fence. If that is the case you will need to adjust your blade. Check your owners manuel to start that process.
Jan 27, 2014 | Craftsman 10" Table Saw
Saw has trubble starting spin when turned on
Your starting capacitor within motor is probably bad.
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Mar 28, 2010 | Craftsman 10" Table Saw
Moter bogs down on my saw can anyonehelp
Jan 29, 2010 | Craftsman 10" Table Saw
Oct 06, 2009 | Craftsman 10" Table Saw
Failed electric motor on 10" Craftsman Table Saw
by seized is it burnt up or are the bearings just bad, the bearings are minimal but the field/armature would be more. Give me the model number and I will try and find a breakdown and let me know what we are looking for and I will try and help.
Sep 28, 2009 | Craftsman 10" Table Saw
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
Re furbish old Craftsman 10'' table saw
It all depends on how much patience you have. It will cut ok, if you feed slowly and use a rip blade to rip with instead of a combination blade. (Buy one with only 36 teeth or 40 teeth). A sharp blade is always a lot easier and safer to use than that old rusty thing that is trying to grind its way through a piece of 2X. Another tip you might try is to put a coat of paste wax on the blade before you start. It will help if there's a lot of pitch building up as you cut.
Otherwise, more hp will be less likely to bog down and overheat, and will allow you to push through denser and harder woods without the danger of overpowering the motor. But even then, a sharp rip blade is a wonder and a joy to use!
Mar 22, 2009 | Craftsman Saws
Craftsman 10" Table Saw Logo
186 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
