Question about Tools & Hardware - Others
Ryobi belt and disc sander
I bought a ryobi table sander about a month ago. 4"x36" belt, and 6" disc. it worked just fine for a month, and then last night, while trying to finish work on a piece of curly maple burl (which is green and needs to be finished asap so i can oil it before it checks and cracks) i flipped the switch on my sander to put some finishing shaping touches on it, and the sander made a pop sound, and didnt come on. it is dead. how can i fix this?
    Top Expert:
  • 19,998 Answers
It's only a month old. Take it back for a repair/replacement under warranty.
Posted on Jul 01, 2017
mikeymiddles
  • 58 Answers
SOURCE: Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Posted on Jan 08, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
SOURCE: Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Posted on Jul 11, 2009
SOURCE: Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Posted on Dec 26, 2009
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
I require a charger, model # 5104-14-2. Thanks.
I do have one for sale. How much are you willing to pay for it.
I just replaced my mastercraft drill for a bosch one. I live in Canada and could sell this part to you for cheap.
Give me news.
Christian Girard
girardchristian@hotmail.com
Jul 31, 2014 | Ryobi Mastercraft Belt/disc Sander Belt...
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Ryobi BE318-2 dust bag don't work
The pathway that the dust follows to reach the bag is most likely clogged. Take the bag off and look inside to see if there's sawdust plugging the orifice. If there is then you could vacuum out the dust or simply start up the sander and let the machine clear itself. If you do the latter just know that you will create a cloud of dust so do it in the proper environment.
Jan 03, 2014 | Ryobi BE318-2 3 X 18 BELT SANDER
I need a 100sl 100 belt drive for a Ryobi radial arm saw or some equivelent
If anyone is looking for the 100SL 100 belt for the Ryobi radial arm saw, I was able to locate a supplier through a phone call with a Ryobi technician last month. Here is where I got them http://store.beltpalace.com/100sl100.html and they were able to ship to my location in a matter of days.
Jun 25, 2012 | Saws
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
Ryobi sander ess-1890 paper retainer clips broken where can i obtain new ones
Easy, take the other side off, get some 4 1/2 sticky disc, slap them on there, never use the clips again. you will be sold. I have about 13 sanders in my shop, all different, all converted to sticky discs, all were clamp on paper type or velcro. The sticky stuff is the way to go. But if you want a clip, let me know, I'll see if I can scrape one up. Besides, Ryobi is real good about taking care of their products, you could call them.
Aug 12, 2010 | Ryobi Tools & Hardware - Others
Belt slipping
Jan 08, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
76 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
