Question about Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB
Heating element for life smart infrared zone heater
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
Jan 31, 2014 | Lifesmart Renew Infrared Quartz Heater...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
A ERR comes up on my American comfort heater
Remove power for some time and switch on after few hours , this might reset any error on the processor , if not the error could be due to fault indication of a failure within the heater, could be the infra or the element.
Oct 02, 2013 | AMERICAN COMFORT ACW0035WE 1500W Infrared...
Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB Logo
212 people viewed this question
Top Lifesmart Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Lawrence Oravetz
Are you a Lifesmart Patio Heater Expert? Answer questions, earn points and help others
