Question about Panasonic Televison & Video
Panasonic TH-42PZ70BA 7 BLINK CODE - Panasonic Televison & Video
4 Suggested Answers
  • 44 Answers
SOURCE: TV will not stay on shows error code
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
Posted on Sep 21, 2009
  • 1768 Answers
SOURCE: I have a Panasonic TH-42PZ70BA Plasma TV.
With the information given here it seems that there is a power supply issue and the TV needs service in the power section or power supply section of the TV.
There is a protection circuit that will not power the unit if there is a voltage overload in the primary section of the power on circuit. This is a warning that something in the circuit is not voltage or current correct and has halted operation.
You need a service tech to diagnose the issue.
Posted on Mar 13, 2010
Seeking an instruction manual for TH-42P270BA
Do you mean the Panasonic TH-42PZ70BA? If so, then the manual is available from ManualsLib: http://www.manualslib.com/products/Panasonic-Th-42pz70ba-3190573.html . The manual is also available on the Panasonic Europe support site. Go here: http://www.panasonic.eu/Downloads/en_GB/popup.html and then search for the model. From there, you will need to accept the Panasonic Terms of Use (a pop-up will open) to view the manual.
I hope this helps.
Dec 06, 2014 | Computers & Internet
6 blink led
How old is the TV? Have you checked for failing caps yet?
Dec 15, 2013 | Panasonic TH-42PZ77U TV
I have a Panasonic TH-42PZ70BA Plasma TV. Went to switch it on & it cut off instantly with the power button flashig red. Tried unplugging and leaving but still the same
Mar 13, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Oct 13, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Jan 08, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
