Question about Goodman Manufacturing Goodman GMS81005CN 100,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed,
Gms81005cn furnace will not light, red light on board not on. Please help!
    Sergeant:
  • 338 Answers
Is your unit plugged in? Check the breaker in breaker box in the house. Does the fan come on? Is your door switch on the unit pushed in it is located in the fan section on the unit just a push button. This sounds like a power problem. Turn on the fan switch to ON on the thermostat to see if it runs this will tell you if you have 24 volts to the board. If it doesn't run then you have a transformer problem or a board problem. I hope this helps
Posted on Oct 20, 2013
  • chuck fanning
    chuck fanning Oct 21, 2013
    It isnt getting any power apparently. i will replace the transformer and see if that is the problem. If not, I guess the board will need to be replaced.
PCBFM103S where is the wiring diagram?
The diagram may be inside one of the service access panels.
Feb 03, 2017 | Goodman Manufacturing Goodman GMS81005CN...
My goodman furance runs on full cycle then it won't start again til i turn power off then back on
May be a stuck relay on the circuit board. The only other thing I can think of would be a thermostat having intermittent problems.
Feb 28, 2015 | Goodman Manufacturing Goodman GMS81005CN...
Induction motor runs/no ignition/red light on
If inducer run and igniter is not come on. 1) check igniter for any damage. 2) check pressure switch to make it close as soon as the inducer run. if it not close check the small tube that connect to it for any restriction( mostly inside the inducer compartment) clear it and restart the unit.
Feb 22, 2015 | Goodman Manufacturing Goodman GMS81005CN...
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Oct 26, 2014 | Heating & Cooling
What do I do if red LED light stays on and my furnace (Carrier WeatherMaker 9200), does not start.
turn power off for 5 min to reset and check thermostat wiring the red wire should be connecting to the white try a jumper at the furnace
Sep 12, 2014 | Heating & Cooling
Nothing working when thermostat turned on.checked voltage at transformer 110 at top and 24 v at bottom,cant figure out whats wrong .any ideas
Be the thermostat. Kill the power to the air handler so you do not burn the transformer. Remove the thermostat from the wall. Twist the red and white wires together and turn the power back on to the transformer. The heat should come on. If it does, the thermostat is bad. If it doesnt, do the same thing but twist the red, yellow, and green wires together and power the transformer up. The air should come on in cool mode.If it does come on then we know what to check next
Oct 27, 2013 | Goodman Manufacturing Goodman GMS81005CN...
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Jan 25, 2010 | Goodman Heating & Cooling
I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Dec 31, 2009 | Heating & Cooling
Goodman Manufacturing Goodman GMS81005CN 100,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed, Logo
55 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
