Question about Goodman Manufacturing Goodman GMS81005CN 100,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed,
Gns81005cn transformer blown? - Goodman Manufacturing Goodman GMS81005CN 100,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed,
  • 148 Answers
Grounded wire
Posted on Nov 10, 2013
What is wrong with my water softener Autotrol 740 Electrical problem?
if there is a bridge rectifier or diodes directly down line of the transformer i would suspect it is bad.. put an inline fuse also on the primary side of the transformer and wouldn't hurt to put a fuse on the secondary also if the transformer only has two wires for the secondary..
May 14, 2014 | Autotrol 263/740 Performa Logix Control...
Rca r52wh72 picture bow and colors off
If this is an ITC 222 chassis, then you have a blown fuse right beside the high voltage transformer (transformer has the large red wire coming out). The fuse is a small brown (square) component. There are two together at this location and one will be blown. Check with an ohmeter. I usually solder a strand of copper wire taken from an ac cord across the blown fuse. ALSO the cause of the problem is bad solder connections on the transformer pins. So inspect the pins carefully for bad connections. (usually the pin going to the fuse mentioned) If you have a soldering iron, then this can be repaired with no cost..just time.
Jun 16, 2011 | Televison & Video
My dog chewed the thermostat wire by the compressor, i replaced the chewed wire now the thermostat won't turn on, therefore; no ac.. could it have blown a fuse? if so, where are they?
Either you have blown the low voltage fuse located inside the air handler (if there is one) or you have blown the transformer feeding the low voltage control wiring.
If the transformer is blown due to no fuse installed, I would recommend installing a low voltage 3A fuse in line with the red terminal coming off the transformer. This will protect the transformer in the future.
Aug 01, 2010 | Goodman CKL42AR42 Air Conditioner
Identifying specs of blown transformer on PCB
I have the same problem, with the same transformer. Did you ever find the specs?
I was thinking of buying the Frigidaire board, connecting to line voltage and measure output voltage.
Jul 09, 2010 | Frigidaire FAC126P1 wall/window Air...
Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
24v----------------
24v----------x----------
24v--------{3ampfuse}----------
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Jul 26, 2009 | Ruud UBHC Air Conditioner
Blown power transformer
Hi
What has happened to the transformer. Does it have an open circuit primary?  Get back to me if you want a fix.
regards robotek
Dec 12, 2008 | Audio Players & Recorders
Baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Blown transformer
Greetings!
GPX just received this transformer in stock, at least for model KCLD8886DT. You can contact them at 314-621-2881 and follow the prompts (I think selection 2) or contact them via email at partsinfo@dpi-global.com. The transformer is $15 plus freight. Good luck!
Rob
Jan 08, 2008 | Teac Audio Players & Recorders
Blown transformer
Do you know the Input and Output voltage on this transformer? The only advice I got 4u is to find the Identical/similar Input/output/wattage for this transformer or find a shop that can rewind a new wire's on that transformer. Hope this may help you
Aug 06, 2007 | Sherwood RVD-6095R Receiver
Goodman Manufacturing Goodman GMS81005CN 100,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed, Logo
37 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
