Question about Zenith ZHX-313 System
Progressive scan can't get off progressive scan mode
  • 2 more comments
  • Anonymous Nov 18, 2007
    can't get off progressisve scan mode
  • Anonymous Dec 04, 2007
  • laurenwenzl Apr 25, 2009
    can't turn off progressive scan Zenith zhx-313
  • bkphelps4 May 13, 2009
    cant get the dvd player off of the progressive scan
This happened to me & I finally found a manual online that I could download.
Here's what the manual says:
"If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that "NO DISC" is displayed on the display window.
2) Press STOP and hold it for five seconds before releasing it. The video output will be restored to the standard setting and a picture will once again be visible on a conventional analog TV or monitor."
Glad I could help because this problem is very annoying!
Posted on Oct 17, 2009
  • yourdaddyrig
    yourdaddyrig Mar 21, 2013
    thanks if it works lol
  • 93 Answers
Did you try to select "INTERLACE"?
Posted on Oct 01, 2007
Não consigo tirar o leitor de DVD fora do progressive scan
Posted on Dec 14, 2010
2 Suggested Answers
SOURCE: Progressive scan mode will not disable
Thank you very much!
This helped me too. I got this DVD player for $10 but have an older TV. I don't have a remote so I was in the dark.
Posted on Dec 16, 2007
How do you get higher than 480p resolution on playback?
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Jan 25, 2014 | Philips Magnavox MWD7006 DVD Player
Toshiba SD-V55HT stuck in Progressive scan mode.
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
My zenith xbv343 dvd vcr combo has a problem when i put on a dvd it says progressive scan mode i cant see nothin else
That means the DVD you put into it to play has recordings with "progressive scan" mode. You have to change the mode of the DVD and TV which you wants to see to Progressive Scan mode to see the disc content. OK.
May 09, 2011 | Audio Players & Recorders
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
Jan 13, 2011 | Zenith XBS444 System
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Zenith ZHX-313 System Logo
652 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
