Question about Freecom Computers & Internet
Broken usb cable connecting usb to hardware inside is broken
  • 127 Answers
Several things and solutions you can do.
if it's just an external hdd you can rip it to bits and take the drive out and use it as an internal drive, or take it to pieces and get an external hdd caddy for the size of the drive (3.5" or 2.5") they are cheap enough to buy.
Posted on Oct 21, 2013
How can i mount micro sd card if slots broken
IF the micro sd card slot is broken, you can always use OTG. OTG stands for On The Go, and all you need is an OTG cable, which at one end is build with a micro usb terminal and at the other end a regular usb. If you use this type of cable, then you need to use an USB adapter for the micro sd card.
Another option is ti buy an OTG adapter, let me explain, there is an adapter for your Micro SD Card, this hardware is ready to connect directly to the smartphone, using the OTG. Here is a link for you to check one of many OTG adapters.
Meenova com Welcome
Jul 18, 2015 | Cell Phones
Hardware id missing
I got that error when my IDE to USB cable went bad. Although it could also be bad/corrupt drivers. Can you put the drive on an IDE cable to check it inside a computer without the USB?
Feb 24, 2014 | Toshiba MK6026GAX 60 GB Hard Drive
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
When i scan a paper it says check connection
Its The hardware Problem
Check or replace the Cable from PC to Scanner or printer. connect firmly.
Problem may be the Strip cable inside the Scanner. Strip cable may be broken. Check and Replace. best of luck
Feb 01, 2011 | Office Equipment & Supplies
Cant extract pics through usb cable to pc! do i need software,,,,,,,,,,,,,,im running a windows 7 laptop
What is the hardware connected through a USB cable to your Laptop? Most hardwares from phones to camera can be automatically connected and transfered ( or either choosing the correct connection prompt on the hardware).
Nov 18, 2010 | Computers & Internet
I have an Alfatel H1A mobile phone, so how to connect to internet with USB cable?
just download the china mobile pc suite and connect the mobile with usb cable,when your connecting usb cable,the system will ask you to install a new hardware.u just install the hardware,in this hardware u will see the china mobile drivers were installed in your pc.and just select the username and password and connect. its very simple.
rajesh kumar kotturi
rajesh.kotturi9@gmail.com
Nov 12, 2010 | Handmark Software MobileLists (950142) for...
Usb communication error: unexpected packet ( 8C080008)
it possible that you are using a broken usb cable to connect to the computer
or the usb port is broken or some dirt inside
Oct 08, 2010 | Texas Instruments TI-84 Plus Calculator
Why don,t my usb-2 cables work with my passport?
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Nov 03, 2009 | Western Digital WD Passport 250GB Portable...
My iomega beeps evert time I connect it to my PC
Hey did u got Y cable with the drive or just normal cable. If you received the Y cable make sure you connect Both power( with the White bolt sticker) and data ends
Apr 02, 2009 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Maxtor one touch 4 mini- not connected! The single USB cable is in the Computer USB port.So far so good. When the second USB connector-with 2 cables is inserted to another Computer’s USB Port I start...
Quite strange.. I would suggest that maybe one of the usb ports is faulty.. Or ofcourse, one of the cables.. Or the usb port has been mis-wired inside the pc. That has been done before. Anyway, do you have access to 2 usb drives.. I mean micro/thumb drives? I'd test each port by itself first, to see if they operate correctly, then if they do, use the two usb drives in the two usb ports at the same time, to test read & write.. I guess there are other things you could try, like going to control panel, system, hardware, device manager & checking on the status of the usb ports. That may tell you something worthwhile. Whatever you do, test each port with the one single cable. Yer, this is a strange fault. Let me know how you go. Rgds,
May 11, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
101 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Mithilesh Kumar
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
