Question about Whirlpool Dryers
Codes F4 and E4 on whirlpool electric dryer - Whirlpool Dryers
I got the same code and after turning the breaker on and off the code went away, but then my dryer would tumble but wouldn't heat. So I took my dryer to an appliance repair shop ( they didn't know what that code meant either) and they told me my dryer was working fine. They told me it could be one of the breakers (2 pole 30 amp breaker) so I replaced my breaker and that fixed my problem. So if you're getting this code that's probably what it is, you have a bad breaker.
Posted on Jan 02, 2015
E4 F4
You don't say if it's electric or gas, if gas check the pilot light at the bottom centre of the oven if it's a very poor flame or is flagged up not burning properly it will cause the thermocouple to drop out and turn the oven off.
Apr 18, 2014 | Whirlpool Kitchen Ranges
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
I have a Whirlpool Super Capacity 465 range and received the error messages E4 F3. What does this mean?
if you call me @ 570 263 0077 i will check my fault code list and let you know what those codes meam thanks JOHN
Nov 08, 2009 | Whirlpool GR460 Electric Kitchen Range
Codes gone
f6-51-aa-63-14-78-b9-77
2e-f4-da-06-d9-4c-8c-40
Nov 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
Looking for codes for ntl uk
00 = E7 22 6E F4 23 E7 8E 7C
01 = 38 B7 C4 44 E4 9E C3 41
Nov 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview Codes N*L
codes for starview ntl uk is 00
E7 22 6E F4 33 E7 8E 7C
01
38 B7 C4 44 E4 9E C3 4I
OK OLD BEEN
Oct 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Whirlpool Duet
your main processing board is having an communitcation error. if you have taking the kickplate off the tech sheets or on the right or let hand wall and will tell you how to enter the diagnostic phases
Jun 01, 2008 | Washing Machines
Dryers Logo
807 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
