Question about Dryers
Battery size for a Hunter UC1018 - Dryers
Where can I get a replacement capacitor for a hunter ceiling fan - Model 25564
capacitors that size are available on line from e-bay or from electronic stores like jaycar
you could try wholesale electrical stores that sell to electricians or a specialist fan retailer
Mar 14, 2016 | Hunter Dryers
What battery replacement for hunter fan remote G0878-01?
Call this number 800-830-1326. They can help but the battery is a A23. 12volt battery. Newer models may use same, but call to make sure.
Jul 02, 2015 | Hunter Dryers
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it .
A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler.
I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats.
ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer
Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
Jun 07, 2014 | Hunter 30124 Air Conditioner
Change blade sizes on Hunter Fan
Yes. Because of the extra weight. The motors are made to accept the weight & size of the blade & blade pitch. You can do it but will probably burn the moter out.
Apr 14, 2013 | Dryers
Model UC1018 wont turn on fan or light. i think the code inside the remote got switched. How do I reset the code or find out what it is?
This unit does not have dip switches on the reciever, there is a process to force the reciever to learn a new transmitter, but good luck finding those instructions.
Nov 24, 2012 | Dryers
I have a hunter cieling fan controlled by a remote, part number 85094-01, FCCID IN2TX13. A replacement battery lasts about a week before needing replacing. I use the standard 12 volt eveready 23A cells. ...
you can call hunter technical support and they should be able to tell you why battery will not last. a bad remote etc. here is the number-- 1-888-830-1326, have a good day !!
Jun 07, 2011 | Hunter Dryers
How do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Dec 12, 2009 | Hunter 30124 Air Conditioner
I have removed the light fixture on my hunter vista iron model 20538. It looks like there should be some sort of a cap that goes on the bottom of the switch fixture. do you know how I might locate one?
There is usually a blank cover that comes with tyhe fan when new, but when installing a light kit they usually get trashed ,, Try any bnuilding supply store that stocks the Hunter fans ,, bring the part for the light fixture so you can get the exact size and mounting screw araingement as the old kit .
Aug 15, 2009 | Hunter 20537 / 20538 The Vista Iron...
What type battery does the Hunter #27157 remote use?
It's a 12v battery, I found this battery in CVS and it was an energizer battery.  It's about half the size of a AAA battery.
Nov 11, 2008 | Hunter 27185 Remote Control
Dryers Logo
Top Dryers Experts
