Question about Cub Cadet Garden
Cub cadet ltx1046 hydrostatic wont go forward or backwards
  • 109 Answers
SOURCE: I have a cub cadet Zero turn mower Z50 and when I
On the transmissions, there are bypass levers...make sure they are pushed in and not pulled out
Posted on Jun 13, 2009
  • 16 Answers
SOURCE: i have a cub cadet model 1450 hydrostatic it will
2 valves on top of trans under finders
Posted on Oct 17, 2009
oldmanewtoys
  • 414 Answers
SOURCE: My daughter gave me her old Cub Cadet model 2145
linkage is connected correct? Did it work prior correct? Did you prurge after changing fluid
Posted on Mar 05, 2010
Testimonial: "Well you were exactly right. I had to remove the two plugs on top and kept operating the lever until I got the oil to run out the top. Runs great."
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Posted on Jun 21, 2010
  • 24 Answers
SOURCE: cub cadet model 1250 hydrostatic still moves in neutral
YOU HAVE TO ADJUST THE LINKAGE DOWN AT THE TRANSMISSION
Posted on Jul 14, 2012
Cub cadet sltx1050 wont go forward or backwards? was w orking fine then we had to push it backwards to jump iot cause it wouldn't start and now it wont move forward or backward
There are two possible options one is the belt for the drive is shot, the other is that the transmission is shot we tend to go out.
Nov 08, 2017 | Cub Cadet Garden
My cub cadet hydrostatic mower will not go into forward or reverse.
Check belt if ok may have bad springs or pressure plate in transmission normally with bad springs or pressure plate it will give warning over period of time by slipping when under load.
Sep 09, 2017 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Depress drive pedal forward or reverse, tractor will not move
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Apr 19, 2014 | Cub Cadet Garden
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
89 cub cadet, 1420, hydrostatics trans, moves very slowly forwards & backward
check the drive belt for ware could be slipping or might need to add oil to rearend
Sep 21, 2009 | Garden
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
64 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
