Question about Ricoh Aficio SP C811DN Laser Printer
My ricoh sp c811dn is displaying the message add toner k, but i just put a full toner in there?. I changed to another black toner and a new pcu drum and the message is still displaying. What can I do?
4 Suggested Answers
newport74
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
Dicedonions
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
andy37718
  • 28 Answers
Here is a way to reset but make sure you follow the instructions correctly.
turn off machine
press online and escape buttons together whilst turning on machine,
when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN.
Turn off printer and wait ten secs then turn back on.
If only temp error this should reset and start up again, Good luck
Posted on Jul 08, 2015
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Apr 03, 2014 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
My Ricoh Aficio SPC811DN printer keeps asking me to replace my PCU colour all the colour carteridges are over half full what do i have to rplace
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Jan 18, 2011 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Add Toner stuck on & Replace Photo Conductor Unit (PCU)
I suspect that it is the PCU causing the problem, and the message should clear once the PCU is installed and it (automatically) runs it's calibration cycle. Likely the toner auger gear has seized on the PCU, and broken. If the light does not go off after installing the PCU, then you may need a technician, as the toner motor may not be working, or there is a blockage within the toner hopper itself.....but again it is likely the PCU, especially if the toner bottle was empty when it needed replacement. Was it empty?? Did the machine work for a few days, or at least for a while? If so, it seems like too much of a coincidence that this problem would come up at this time.
Good Luck :)
Mar 18, 2009 | Office Equipment & Supplies
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio SP C811DN Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
