Question about Technics Audio Players & Recorders
Technics Turntable SL B350 --- Can you recommend some good cartridges that match well with this model?
  • Ron Pierce
    Ron Pierce Oct 22, 2013
    The turntable currently has no cartridge, some have recommended specific Grado cartridges for other models of Tecnics turntables, but I want to feel confident tat a new cartridge will properly matc the tonearm of this model. Thanks for any suggestions!!
  • Ron Pierce
    I also need to clean my computer keyboard, as some keys like the h do not always make contact...
    Guru:
  • 417 Answers
STANTON AL500
Posted on Nov 03, 2013
  • 7 Answers
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Posted on Dec 18, 2007
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
djproaudio
  • 515 Answers
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
  • 256 Answers
SOURCE: How do I remove the platter on a sl-bd22 Technics
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Posted on Jul 13, 2010
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
Replacement Cartridge and stylus for Technics SL-D1 Technics Turntable
That turntable, like many others, has an S-shaped tonearm with a removeable headshell. You can use any standard screw-mount cartridge as a replacement. Which one you buy depends on what you want to spend and your intended use. If you're a DJ you'll need a more rugged cartridge than you do for listening at home, for instance.
One company I buy lots of parts from is Parts Express. Here's a link to their styli/cartridges pages. If you have the original cartridge and stylus, you can check if they have the exact replacement. Otherwise you can browse the other choices. You can find many other sources as well, and you may have an audio shop or musician's store in your area who stock cartridges.
Jan 02, 2011 | Technics SL-1200MK2 Turntable
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
New cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
Feb 03, 2009 | Panasonic Technics SL-BD22D Turntable
Cartridge
"at3482p-de" <--do a search for this at yahoo. the resulting cartridge is correct for your model. it comes with the needle as all cartridges do. There are better ones you can get but this one is aprox. equal to the original supplied with the unit. In short any pmount type cartridge will fit/work in your player.
Jan 29, 2009 | Technics SL-BD22 Turntable
What cartridge do I buy for this turntable
You should get a headshell first of all. Into the headshell you install the cartridge. I would get a Technics headshell just because it is of the same brand, and I use a SHURE M35X cartridge which is mean for dance or electro music. The headshell is your option but the cartridge should be matched up to what type of music you will be playing. Good Luck
Sep 01, 2008 | Technics SL-1200MK2 Turntable
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
85 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
