Question about Broan-NuTone Dryers
I have a Nutone 9093n. The exhaust fan and light work fine. The heater did work fine but has quit. I am not sure how to troubleshoot. The wiring appears in very good condition and the heating elements are not burnt out. I would appreciate any offers of help so I can determine if I should buy parts or just replace the entire 9093n. Thanks, Jim
Store for parts is the best place for replacement of the part of exhaust fan broan range hoods parts, broan parts and for more iformation to click on links.
Broan Range Hoods Broan Range Hood Parts NuTone Exhaust Fans NuTone Fan...
Posted on Apr 05, 2014
    Problem Solver:
  • 16 Answers
Why the heater is provided in the exaust fan?? I am not getting the problem.
Posted on Oct 20, 2013
  • 95 Answers
SOURCE: heater doesn't work
You can purchase heating elements for this fan that will solve the problem. This is a fairly new fan model so I would recommend calling Nutone because this model has a three year warranty. They may send you the part you need for free.
Posted on Jan 28, 2009
bargainbin2
  • 123 Answers
SOURCE: Older Nutone bath- fan/light/heater Model
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Posted on Aug 29, 2009
digritz
  • 530 Answers
SOURCE: where can I get the motor unit to replace?
The motor is a common item to need replacement in bathroom vents. Replacements can be found just about anywhere that deals with electric motors. You might even be able to get a replacement where you originally purchased the unit. There are dozens of web sites that you can locate a replacement. http://www.electricmotorwarehouse.com is just one. Simply do a web search on replacement bathroom vent motors. Also if the are able to purchase items from wholesale vendors you can get one from Grainger's. It should cost around $20 to $25
Part # 62345-000 (replacement motor part #).
However there is an alternative to replacement. This depends entirely on how handy you are with these kinds of things and how bad off the motor is. If your not comfortable with repairing this kind of thing don't bother with the rest of this.
I hate to replace anything that may be repairable. Unfortunately my friends know this and recently one asked me to look at his NuTone bathroom vent motor before he replaced it.
For the cost in time of an hour I was able to refurbished it.
A good way to check if it's a candidate for repair is to check how much play is in between the shaft and bushings. If you can feel movement then it's best to go ahead and replace it. If the problem is that the shaft is tight and just hard to turn then it may just need some cleaning and fresh lubrication.
The steps are simple. Once you have the motor removed from the vent cage you will see a pair of nuts and bolts holding two brackets in place. These brackets(one on either side of the coil) are what hold the shaft centered and house the bushings. Remove the bolts and the brackets. Be careful not to lose any of the washers on the shaft. These are spacers and need to be replace the same way they went on if they come off. All you need to do is clean both ends of the shaft put a little oil on the shaft and in the bushing and put it back together. If the motor has a plug and not just bare wires for reconnecting to the power supply then it's safe to just plug it in to any outlet for testing after you remount it in the vent cage. You will know right away if you were successful.
Hope this helps.
Posted on Oct 16, 2009
SOURCE: Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Posted on Jan 18, 2010
Testimonial: "THANKS! I brought an electrician in after I smeleled burning and there was bad arcing going on. He rewired it properly and everything is good now. T"
heatman101
  • 43501 Answers
SOURCE: Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Posted on Feb 28, 2010
What is comparable replacement for Nutone 9093N fan motor?
Broan NuTone
Your fan is a $56 item. It may be more reasonable to replace the whole fan assembly rather than just the motor.
Dec 08, 2014 | Dryers
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Ceiling fan not working. How do I remove the fan to see if the vent is clogged?
Usually the cover pulls down, and is suspended on wires.
Push together the wires to release cover.
Use vacuum to clean.
Dissemble using screwdriver if possible. Some newer fans are one-piece and cannot be taken apart.
See if fan turns on.
Open wire cover and inspect wires.
Use non-contact tester to see if unit has power when switch is turned on.
See if switch is good.
If fan does not turn on, then wires are loose, switch is bad, fan motor is bad.
Some fan motors are sold separately, and some are not, and whole unit has to be removed from between the joists, and new fan installed.
Dec 05, 2011 | Broan-NuTone Nutone 70 CFM Deluxe Ceiling...
Model 100HFL...with the light switched on I turn on the exhaust fan and the light dims a bit and the exhaust fan works. with the light switched on I turn on the heater and the light goes completely dark. ...
I'm not sure what is going on without full and complete description of wiring and switches:
Add a comment with exact information for possible help.
Specs say 20 amp circuit is needed: so 20 amp circuit breaker + 12 gauge wire are required.
Heater uses 1500 watts, so it pulls a lot of power if same circuit breaker is used for several other rooms and a TV etc. Turn off everything else and see if problem persists.
Sell sheet for product says: Energy efficient lighting - uses one 27-watt (max.) high efficiency GU24 based fluorescent lamp.
Turn off power, and disconnect ground wire. Turn power back on and switch on the heater-lite and see if there is a fault to ground.
Use a different switch.
Aug 11, 2011 | Broan-NuTone Broan...
I installed the Nutone vent fan light combo with night light and I want to put the fan and light (not night light) on one switch, and not use the night light at all, is this possible? Thank you.
yes there should be 3 wires coming from light one for light one for fan and one for night light just dont hook up night light wire should work fine tape or cape the wire you dont want to use. good luck
Aug 05, 2011 | Broan-NuTone N-8663RP Combination Light...
NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
NUTONE FAN 8310: WHAT IS THE CORRECT WIRING FOR AN EXHAUST FAN WITH DUPLEX SWITCH?
It does not matter whether the power goes to the fan unit or to the switch box, you still need 3 insulated wires going between the switich and the fan, and the ground wire as a 4th wire. If power is at switch, you will have white as nuetral feed to fan and 2 blacks (or a red and a black) one each to bring power for light and power for fan or heater element. ( if so equiped). If power is to fan unit, the white wire must have a piece of colored tape (red, orange, blue, brown) and this whtie wire is attached to the black power wire. The tape shows that this is not a neutral. The tape has to be at both ends of the white. Now, the other 2 wires (blk & blk or red & blk) can be atteched to the switch and carry the elec. to the fan light, blower, and or heater. Goodluck, Macgivor
Jan 02, 2010 | Broan-NuTone N-769RF Combination Light Fan...
Dec 06, 2009 | Broan-NuTone N-668RP Combination Light Fan...
Heater doesn't work
Jan 28, 2009 | Broan-NuTone QTXN110HL Fan
Dryers Logo
440 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
