Question about Vacuums
Dc 45 powerhead not spinning - cleaned rollers, cleaned filter, emptied and cleaned bin
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Most likely a bad brush motor. You will have to replace the whole nozzle assembly. Dyson doesn't sell the motor seperately for this model and it's a known failure item.
Posted on Oct 21, 2013
yeroc
  • 397 Answers
SOURCE: Filter Queen powerhead diagram
what model majestic?
Posted on Jan 20, 2008
  • 61 Answers
SOURCE: irobot 4100 brushes do not turn & bin is empty
Yes, it probably needs a new cleaning head module, if your bearings are clean and the brushes still don't turn.
Posted on May 15, 2009
tvservice306
  • 458 Answers
SOURCE: Animal vac gets dog hair in the HEPSA filter,
no id try call Dyson
Customer Service - 866-693-9766
Posted on Nov 05, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: I have a Filter Queen
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Posted on Feb 22, 2010
pappapumpdaf
  • 635 Answers
SOURCE: roomba 550 dust bin always empty
Sounds like you either have a very clean floor, and only dust remains OR, you have dust and baby powder on the floor clogging the hepa filter. THIS time wash the filter with water, then check for blockage in your waste gate area.
Posted on Mar 11, 2010
D.C. 17 makes a loud whining noise when beater brushes are engaged. Normal sound until then. Replaced belt. Still so loud it hurts my ears!
Could be the brush roll, remove brush roll and see if noise is still there when brush roll motor is running.
Sep 18, 2017 | Vacuums
My Dyson DC-59 is pulsing when I try to use it. The dust collector is empty and I put a new filter in.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc59
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 08, 2016 | Dyson Vacuums
Dyson V6 animal powerhead starts and stops does not run continuously
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
Ava B.
Nov 24, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
Why doesn't brush roller rotate?
The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
The brush on my Pet Power Mate attachment for my Kenmore isn't spinning. can it be fixed?
In my case the brush was seized on the axle. A wad of pet hair had wrapped one end and melted the plastic roller a little, binding it to the axle. Take the powerhead apart; Pull the white ends off the axle; Push the axle out; ream out the holes in the roller ends with the proper sized drill (#12 or 3/16", I think...close is good enough); Clean any debris out of the roller and steel wool the axle if necessary; Light oil lube job; and reassemble.
Feb 02, 2012 | Kenmore Vacuums
How to clean
There are 2 Filters that should be washed every 3 months. they are labeled as filter A and Filter B. They only neet to be washed with water. if you use any type of soap or cleaner it will actually damage the filters and they will need to be replaced.
Another part of the vacuum that can be cleaned is the clear bin assembly. REMOVE it from the cyclone before cleaning it. DO NOT get the cyclone wet. it will damage the machine. but again just water and a rag on the bin assy will work great any type of cleaner will actually cause the bin to get foggy.
The only other part to be cleaned is the roller brush. what i would recommed is to take a box cutter, and to cut the length of the roller. all of the hair and fibers on there. then turn the roller brush 180 degrees and cut it again. then turn the vacuum on and vacuum with it for a minute and the debris from the roller brush should be gone.
Sep 17, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Nov 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
F7452900 the brushes won't rotate during floor cleaning
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Apr 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
