Question about Dishwashers
Beko dishwasher dsfn 6830. Stops 1 minute into any programme
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
  • 1462 Answers
SOURCE: BEKO D 2731 FW Dishwasher Problem
possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
Posted on Jun 21, 2008
  • 5 Answers
SOURCE: My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
Posted on Aug 12, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have F&P DD603 with
Hi
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
This dishwasher has a diagnostics mode which can be entered but you need the service manual which is attached to the back wall inside the cavity ( you can see it if you pull the drawer all the way out but you cant reach it without removing the drawer from its roller guides.) You can enter the diagnostics mode by pushing keylock,and holding it in. Then push and hold start/pause in that order. If you push start pause first it just counts through a delay start.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
  • 3247 Answers
SOURCE: I have the double drawer
A few things you could do.
Is this happening with both drawers.
Take a clean damp cloth and wipe the switches and the inside panel.
Get a couple of Finish dishwasher cleaner kits from the local woolworths/ safeway and run each drawer separately with one kit in each. You will have to select at least the 99 minute cycle.
This should help with having cleaner dishes.
Hope this helps. Please rate the solution if you find it helpful.
Posted on Sep 04, 2010
We are trying to replace a door handle on a beko dishwasher DSFN 1530B. We cannot remove the programme panel all screws have been removed and we are stuck. Can you advise
before you can remove the top panel you have to remove the front outer door panel, there are screws down the sides to remove it.
May 14, 2017 | Beko Dishwashers
The start/pause button on my Beko dishwasher DSFN 6831 W is stuck in on position. Lights are on but machine does not start.
I think you have a control board fault, this is the part that is connected to and part of the buttons.
Mar 23, 2017 | Beko Washing Machines
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
My tablet will not dissolve ?
The usual cause for dishwasher tablets failing to fully dissolve is a failed dishwasher heating element.
Sep 21, 2010 | Beko Dishwashers
I have the double drawer dishwasher. It is 3 years old. For about 1 year now one of the programmes - the second one along which is for quite dirty crockery and cutlery (programme is about 99 minutes) -...
Aug 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Nov 30, 2008 | Beko 24 in. D3421F Free-standing...
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
258 people viewed this question
Top Dishwashers Experts
