Question about Uniden Lands Phones
How to put speaker phone on my uniden 6.0 phone menu how to use phone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model Uniden DECT 6.0 phone?
Posted on Oct 20, 2013
Uniden dect 6 0 manual
Select the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jul 14, 2014 | Lands Phones
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
How to change the ringer tune on a uniden d1660 dect 6.0
You can download a copy of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660om.pdf
The ringer tone is in the "Handset Setup" menu (page 6). You can also assign a personal ring to each person in your phonebook (also on page 6).
Sep 11, 2011 | Uniden D16602 Twin Cordless Phone
Does my Uniden DECT 6-model 2060-2 have speaker phone ability or do I need to upgrade?
The 2060-2 does have speakerphone ability. Simply press the speaker button during the call to switch between speakperphone and "normal" modes. The speaker button is at the lower-right-hand corner of the keyboard, marked with a speaker icon, located below the # key.
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT2060-2om.pdf
Aug 05, 2011 | Uniden Cordless Phone
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
Changing the amount of rings on uniden DXA15188-2
On the main base, press the menu/clock button 3 times, it will give you 3 options...2 times, 4 times, and 6 times, press set.
Jul 29, 2008 | Uniden Cordless Phone
How to mute my Uniden phone
You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
Mar 31, 2008 | Lands Phones
Lands Phones Logo
48 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
