Question about RCA L32HD31 32 in. LCD HDTV
What size bolt are the wall mount on the led32b30rq on back of tv
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
What bolts/screws do i need for the holes at back of tv for wall mounting
The screws usually come with the mount. The size of the screws depend on the size and weight of the TV so there is no one answer.
Oct 22, 2015 | Panasonic TX-P42S10 42 in. HDTV-Ready...
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
Bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Mounting TV
Assume you are mounting on the wall, if so a good mount will have the standard bolts in the package. If this is a used mount, you will need to determine the length based on the mount, the bolt size is either 1/4" or 5/16", probably the latter.
Dec 14, 2007 | Panasonic TH-50PX75U Plasma HDTV
RCA L32HD31 32 in. LCD HDTV Logo
88 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
