Question about Proscan 40LC45Q 40 in. LCD TV
What is the likely problem when the telivision cuts off as soon as it receives a signal from an outside source?
The telivision cuts off as soon as it receives a signal from an outside source?
    Top Expert:
  • Proscan Master
  • 75,157 Answers
Defectivce ABL [Automatic Brightness Limiter] problem can cause this.
Posted on Oct 21, 2013
Since I canceled cable, bought a GE advanced HDTV a flat antennae , and a universal. GE remote,I have not seen TV. I cannot get the remote to give me a signal. Need phone support.
well the TV needs to be attached to some outside source of signal if not cable then you need an antenna .either inside or outside and that will depend on how close or far you are from the stations
Jan 29, 2015 | Televison & Video
Trying to hook tv up outside of house ran cable from box in my house wont run my tv outside can I buy hdmi ******* and have it work ? Thanks
I'm hoping you hooked the cable you ran for the outside tv to the output of the cable box and didn't make the mistake of splitting the cable that comes into the satellite box. If you take the cable that goes to your TV inside you should be able to put a splitter in it and run the TV inside as well as the one outside. If it is a long distance to the outside TV you may want to buy a powered splitter that amplifies the signal. You should also be using RG6 coaxial cable to cut down on lose.
Sep 22, 2014 | Audiovox Directv Rca Drd430rg Receiver...
Digital surround mode doesn't work,just analog dvd 6ch.input
Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sep 29, 2011 | Technics SA-DX850 Receiver
I cant connect my dish satalite to my ILO telivision, should it be connected to the ATV port or the DTV port.
If you satellite is HD don't connect it to either port, Use an HDMI or component (5 wire cable) so as to receive high def signals. If you must uase channel 3, You want the ATV input. On channel 3 YOU WILL NOT RECEIVE HD PROGRAMMING> check your hookup guide from Dish network.
Jul 09, 2011 | iLO Televison & Video
How to correctly set up a media center computer. I have set scene 1 there is a digital line from computer to receiver I get sound from Win media center when playing music and analogue television but...
At the rear of the Yamaha, on the left side, you will see 3 connectors for Digital input - the 2 one is specifically set for an HD tv / DTV. Buy a optical cable like
http://www.amazon.com/AmazonBasics-Toslink-Digital-Optical-Meters/dp/B001TH7GSW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1297066417&sr=1-2
and connect it between the tv output and the receiver then select it as a source from the menu . Now you will have sound.
Feb 07, 2011 | Yamaha RX-V363 Receiver
I have a TV sharp CATV bought in Belgium but installed in France where I cannot find the different channels. Can you send me the directions for use. Thank you.
Hello
The TV you have bought from Belgium, Sharp 25R-S100_ model can only recive NTSC [National Telivision System Commitee], signals only. It is not a multisystem compactable one. In France, the telivision boradcasts are in SECAM system I thinks and knows. [It is known as Sequrntial Colour and Memory]. The TV you have bought will work in US and other countries like that, where there transmission sytem is NTSC. I don,t know whether in France there is TV stations transmitting on NTSC system. If have, your TV will receive that transmissions. It is a system compactibility problem.
If the matter is so, nothing can be done to receive programmes transmitting in SECAM system. If a system convertable device is available in France, that is SECAM to NTSC system converter, you can connect it according to the instruction manual come along with that device.
Your TV is capable of receiving 181 channels and have PLL[ Phase Locked Loop] channel locking system, but have only capable of receiving NTSC RF signals. Ok
Oct 29, 2010 | Sharp 25R-S100 25" TV
No satellite signal
Some vehicles have a coating in the windshield that can interfere with the GPS unit receiving the satellite signal. It is not the unit's fault. You may need to purchase an external antenna to allow your unit to work inside your vehicle. These are available at www.garmin.com or at your local GPS retailer.
Nov 29, 2009 | Garmin nuvi® 200 Car GPS Receiver
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
THE EXACT SAME ISSUE. THE CONTRACTOR IS NOT BEING ACTIVATED.
Then the contactor is not receiving the signal to pull in from what ever control unit sends the signal.
Aug 01, 2009 | Ruud UBHC Air Conditioner
Component Video losing sync with too much White signal
I had this exact same issue. I tried two different component AV switches, and shorter cables to prevent signal loss, but any time there was too much white on the screen, the video still lost sync. Plugging the sources directly into the TV solves this problem, but since I have a DVD player, a game console, etc, this was not acceptable. The way I resolved it was to (sadly?) buy an expensive component AV switch that can support the bandwidth without losing the signal.
I wound up spending the extra money on a Key Digital 4x1 component switch. It is much more expensive, but it works.
May 02, 2008 | Onkyo TX-SR604 Receiver
Proscan 40LC45Q 40 in. LCD TV Logo
56 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
