Question about Kitchen Appliances - Others
Grommet under paddle has disintegrated. where do I locate another one?
    Genius:
  • 1,280 Answers
It takes a lot of skill to replace the little gasket. My recommendation is to replace the whole pan. Try breadmachinepartsfinder.com
Posted on Oct 23, 2013
1999 Pontiac Firebird manual transmission. Reverse pops out of gear.
Check the linkage first. They put plastic grommets on the arms. They disintegrate. After that, it is internal. They also put plastic tabs on the shift forks. Could be a bad gear.
Jun 11, 2016 | 1999 Pontiac Firebird
I have a 1970 motor home that is stuck in drive what could be wrong with it
More information is really needed, but a lot of older motor homes had very long shift linkage rods that are not at all straight. They also used rubber grommet bushings on the links that soon disintegrated causing the linkage to bind. If this is Dodge based, they also had steering column problems.
Jan 26, 2015 | Cars & Trucks
1986 Chevy van. How do you ajust transmission shift linkage? When you put it in reverse you got to hold it just right for it to shift and engage.
Probably just need to replace the plastic grommets that disintegrated. Two of them gone will cause your problem. Adjusting it will only cause hard shifting in forward gears.
Nov 16, 2014 | Cars & Trucks
2001 taurus wagon the rear door will not lock or unlock with a key or the fob What should i look for?
There's a rod connected to the latch, it's most likely disconnected because the plastic grommet has disintegrated. Remove the door panel and inspect to assure my diagnosis.
Jul 12, 2014 | 2001 Ford Taurus
My sunbeam breadmachine started getting the oil spots,leaked into dough and eventually whatever held the paddle shaft onto the bread pan disintegrated or disappeared. Would that be the seal or some kind...
Hi
As long as the drive mechanism beneath the pan is still stiff to turn and fels like it engages the motor you should be fine. See pic. The centre 4 spike drive unit is what is important. Normally the toothed drive belt will fail. If this is still good then replace the pan.3f754847-72d6-45ec-a55c-8ca7f7deffab.jpg
May 29, 2014 | Sunbeam 5891 Bread Maker
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
I have a GE Profile refrigerator model PFSS5PJXA SS, French doors with bottom freezer and water dispenser, no ice, on right door. A small rubber disk fell of from behind the paddle that the glass is...
I removed the control panel (2 tabs under the front edge) removed the 4 screws holding on the paddle assembly and removed the assembly. The disk is glued on the back( I used super glue). If it happens in the future I would try to glue it on without removing everything. If you use a mirror you can see the detent where the disk mounts to the paddle and glue it back on. The disks function is to push on the switch that is located behind a gray rubber panel behind the paddle.
Aug 06, 2010 | GE Refrigerators
How do you change the speedometer light bulb?
Your '01 is probably the same as my '03. Take the tank 'beauty covers' off and the dash like you were going to change the air filter located under the center dash. Once you get the dash off, unplug the electronic cable from the speedo housing. 4 screws will release the speedo housing from the dash assembly. There are black grommets covering the bulb access (4 across the bottom: Low Fuel, Hi Beam, Blinker, Neutral). And 2 grommets about mid way on each side: these are the speedo lights. Just pop the grommet out and the bulbs are right under it. Replace and reassemble.
Jul 03, 2010 | 2001 Suzuki VL 1500 Intruder LC
95 honda accord 2.2 vtec, oil is leaking out of the hole for the dipstick tube connecting to the engine, the o-ring is not keeping the seal, what can I do? When it was pulled out at first it looked like...
an oring, may work in the right place on the tube. at my shop, we either replace the grommet if it is accessable, or pull out the dipstick tube, put some rtv on it, and let it seal that way. it sometimes works with rtv, but not always, and you hva to be careful not to get it in the engine.
Feb 26, 2010 | 1995 Honda Accord
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
