Question about Dometic RM2620R Classic Fridge Refrigerator Refer 2-Way Small Double D
Energy selecter swich
Fridge won't operate on any fuel
    Sergeant:
  • 405 Answers
Do the lights come on when the door is opened? If not you have lost 12vdc to the circuit board. If they do come on and the heating element will get hot but the refrigerator will not cool and same result on LP gas then you more than likely have a bad cooling unit.
Posted on Jul 02, 2014
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
Ge profile side by side sweating on frig wall next to freezer
Your fridge may have an optional energy saver switch set to on. This turns on & off the heater strips along doors and other key locations.
When set to ON (or the Energy Saving position), energy savings is realized as it powers down the heaters that are designed to evaporate the condensation that can naturally form there - especially in warmer / humid weather conditions.
Slide the switch to OFF to to disable energy savings and have to pay for additional power to operate these heaters. You may find that you need only select this position at certain times of the year. Experiment to see if you can enjoy savings during the other times of the year.
Play the video below for additional help.
Energy Saver feature explanation
Mar 24, 2015 | GE Refrigerators
Will frost build up affect the temp in my fridge?
No, the thermostat will try to keep the temperature within just a few degrees from what you select. But too much frost, will cost extra energy, because it takes longer to reach the temperature selected.
Jul 27, 2014 | Whirlpool Refrigerators
My corsa energy won't start there a ticking noise coming from the purple housing relay cann't locate in manual what this operates can you shine sone light my way thanks
that will be the fuel pump or injector relay ( should be 2 there on left fuel pump right injection system) eather way if one not working engine will not start. if it is clicking then it needs to be changed.
Feb 21, 2013 | Vauxhall Cars & Trucks
Hi will work on gas will not work on 110
This refrigerator is equipped with a control system, which can automatically select the most suitable energy source which is available, either 120 Volt AC or LP gas operation. The refrigerator can be operated in either the AUTO mode (thermostat factory preset below the safe food storage temperature) or MANUAL mode (continuous operation - no thermostat control).
NOTE: Under certain cool weather conditions, the food in the lower portion of the fresh food compartment may freeze if operated for an extended period of time on the MANUAL mode.
A. A 12 volt DC supply must be available for the electronic control to function. The refrigerator will work down to 9.6 volt DC.
B. Press the main power ON/OFF button (1) to the DOWN position.
B. In AUTO mode operation, the temperature is controlled by a single temperature setting, on the energy source selected by the control system. (See Auto Mode)
C. In MANUAL mode operation, the refrigerator will run continuously on the energy source selected by the control system. (See Manual Mode)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Dometic RM2652 Refrigerator
When setting fridge temperatures is low cool best?
high and low relate to the speed at which the unit will reach operating temp..low saves energy.high is for newly stored food.
Mar 10, 2010 | Refrigerators
My GE Profile Artica very hot spot on the left side about level with the ice and water dispenser. The freezer and refridgerator seem to be operating fine but this hot spot seems to be indicating something...
There is a defrost element installed in the cabinet that is designed to keep condensation (which would lead to icing) from forming on the surface of the fridge. This is normal and there is no switch to turn this off completely.
Your fridge might have an "Energy Saver" switch inside the fridge compartment that you can turn "ON" to reduce the usage of the cabinet heating elements. Turning the switch "ON" turns off the heaters or reduces their power draw; Turning the energy saver switch "OFF" means the heaters are running all the time, thus consuming more energy, etc.
The heaters installed by the dispenser panel are usually not connected to the energy saver circuit, but it varies depending on models and year of manufacture. Either way, it is nothing to worry about as it normal part of the operation of your fridge.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Refrigerators
The divder between my frig and freezer is also hot
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
Jul 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
Is my fridge energy star rated?
ALL ENERGY STAR APPLIANCES HAVE A "ENERGY-STAR LABEL" USUALLY LOCATED ON OR NEAR THE MODEL AND SER. NUMBER TAG OR LABEL. CHECK ON THE BACK OR INSIDE THE REFRIGERATOR WHERE THE COLD CONTROLS ARE LOCATED.
Apr 26, 2007 | Kenmore 53612 / 53614 Side by Side...
Dometic RM2620R Classic Fridge Refrigerator Refer 2-Way Small Double D Logo
19 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
