Question about Kichler Lighting 300106OBB Ceiling Fan
My remote control will only turn fan only, will turn light on and off but will not turn back on.
    Problem Solver:
  • 16 Answers
Check the conditon of cell (batteries) inside the remote. If requried, replace it with new one.
Posted on Oct 20, 2013
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
Light goes on by itself
My solution for intermitent light on/fan off-on: It is not outside interference. It is defective receivers. I took back my second 27185 back to Menards with the exact same problem as the first. I went to Home Depot, bought a Hampton Bay model 191-691 remote unit for $8.00 less with same features and when you turn the lights off then back on, the receiver remembers the brightness level you turned off at. Been installed for a week now with no problems. Hunter would have acted up the first day.
Sep 07, 2009 | Hunter 27185 Remote Control
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Fan and remote not working
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Kichler Lighting 300106OBB Ceiling Fan Logo
282 people viewed this question
Top Kichler Dryers Experts
Are you a Kichler Dryer Expert? Answer questions, earn points and help others
