No clutch on renault megane2 scenic - Computers & Internet
    Problem Solver:
  • 16 Answers
Check if the clutch pedal is an hydraulic operated clutch if yes check your brake fluid level and top up if low. Have look to check for hydraulic leaks if there are none there must be a mechanical fault with the unit. The gearbox may have to be removed and the clutch inspected. Good luck.
Posted on Dec 30, 2013
About gear box renault scenic megane hard to change gears
Sounds like you have a badly worn clutch plate. Have shop confirm this.
Apr 30, 2016 | 2005 Renault Scenic 1.6
Renault scenic will not start when brake peddle pressed but will when cluth peddle is pressed
That is called a Clutch Safety Switch. Most cars newer than 1980 have this. It won't allow the car to start unless the clutch is pressed.
Apr 09, 2014 | Renault Sportwagon Cars & Trucks
checkl on the clutch cylinder if its leaking then fix the clutch kit then it work
Oct 20, 2013 | Cars & Trucks
How to change a clutch jn renault grand scenic 1,6 2005
Take it to a garage ,too much special equipment needed ,like a four poster ramp ,dropping the front sub frame ? not a job on a side jack and axle stands
Mar 27, 2013 | 2005 Renault Grand Scenic
Renault scenic battery charge fault
I had my clutch replaced yesterday on my renault scenic grand and now the battery charge fault is showing on the display and the battery has completely died
Apr 22, 2012 | Cars & Trucks
Where is the adjustment for the clutch on a renault scenic 2004
I have a renault megane scenic 1.4 16v 04 plate my clutch is extremely high I only have to push down a 1mm or 2mm for bitting point is there anyway I can adjust it I did take it back to the garage I bought it from and they just dismissed the issue saying it's fine the pedle is easy to push still the car has sone 77thousand miles thank you for any help
Mar 22, 2012 | 2005 Renault Scenic 1.5
Renault scenic y plate wont go in first or second gear so which clutch do i need i have been told theres two clutches
If you do have two clutches , then they come as one unit, you have to replace them both
Nov 22, 2010 | 2000 Renault Sportwagon
My renault scenic i hard to change gear
possible clutch cable or cluth itself, check the clutch cable first to see if its stretched, i didnt check and put a new clutch in ,and wasted £250 , try euro car parts for cheapest clutch cable.
May 17, 2010 | Cars & Trucks
Clutch problem 1.5 dci scenic 05
you have checked brake fluid.
if ok then clutch.
if fluid low, fill, bleed the slave cylinder and its cured
Jul 02, 2009 | 2005 Renault 181
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
