Question about Samsung SF-760P Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop - Printer, Scanner, Copier, Fax - 21 ppm Mono Print - 1200 x 1200 dpi Print - 21 cpm Mono Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB 63
Factory reset on Samsung sf 760p - Samsung SF-760P Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop - Printer, Scanner, Copier, Fax - 21 ppm Mono Print - 1200 x 1200 dpi Print - 21 cpm Mono Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB 63
The fax not sending only to one number. it show comm. error on the screen. all other numbers are ok
This sort of problem is very difficult to overcome as there are a few reasons as to why this is happening.
1. The machine at the other end may be a very old model and not compatible with yours.
2. It maybe in the third world where the line quality is still poor.
3. The other machine is not turned on or may have it memory full.
4. Your machine will need to have its speed reduced to overcome communication problems.
5. Your machine is transmitting to loud so the other machine hears it slightly distorted.
Its very unlikely you will solve the problem. Sorry.
Dec 07, 2015 | Samsung SF-760P
Samsung sf-365tp wont answer incoming calls
please reset the phone set to factory settings
Sep 09, 2008 | Samsung Lands Phones
I have a samsung sf-760p i just changed the toner cartridge it is just showing not compatible toner cartridge but am using the original toner cartridge. so what can be the solution for this problem??
I suspect you think you are using a genuine samsung cartridge but its simply not. The machine is looking at the chip in the cartridge and its not genuine. I suspect your cartridge did not come out of a genuine blue and white Samsung box or its similar but not the correct one.
Dec 02, 2015 | Samsung Sf-760p Laser Print/copy/fax/scan
Samsung sf-5100 says job waiting cannot get job to clear
take the power out. hold the stop (red button) in and old it in put the power back.
this is a factory reset.
Jul 11, 2011 | Samsung SF-5100 Plain Paper Laser Fax
How to reset 565 samsung?
samsung sf-565pr printer chip reset
May 30, 2011 | Samsung SF-565PR/XST Printer
How to get Chips Samsung Fax SF-565PR ?
Samsung sf 565pr toner reset software
Oct 07, 2010 | Samsung SF-565PR/XST Printer
Fuser error
No reset...fuser will need to be replaced.
May 10, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Error light blinks
If I am not mistaken:
Press "menu" or "Function"
then go to last item, either 7 or 8, it should be Factory reset function
Press SET
and the machine is cleared.
Good Luck.
Mar 10, 2009 | Samsung SF-3100 Plain Paper Inkjet Fax
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-760P Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop - Printer, Scanner, Copier, Fax - 21 ppm Mono Print - 1200 x 1200 dpi Print - 21 cpm Mono Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB 63 Logo
503 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
