Question about Acer Aspire Computers & Internet
Aspire 5684wlmi bluetooth driver win7 - Aspire Acer Computers & Internet
Needed Drivers For Aspire ES1-512 Laptop FOR WINDOWS 7 32 BIT
If Acer never made it compatible with windows 7 in the first place you are out of luck. They made it to work with 8, so they had no reason to support win7, therefore it doesnt and you should.... install 10! or 8.1
Jul 24, 2015 | Acer Aspire Computers & Internet
Driver bios acer aspire 1700
Hi
I found the specs for this machine, and if you have sufficient RAM and a larger hard drive than given here:
Acer Aspire 1700 notebook specifications
it looks as if it should run Win7 albeit probably slowly as the machine is fairly elderly.
All the official drivers, manuals etc can be found here,
Drivers and Manuals
by selecting the relevant sections,
ie >Notebook >Aspire >Aspire 1700
and using the tabs below the selections to go to the section you need.
Worryingly the only OSs that the site mentions are XP and XP 64bit, which may mean that Win7 is not compatible with your machine.
I did further research and found a lot of posts about this machine and Win7, nearly all of them relating to the BIOS not being fully ACPI compatible. If there is no upgrade to make it fully compatible (I couldn't find one that said it was, certainly not from Acer), then Win7 will not install on your machine.
Not perhaps the answer you were hoping for, but nevertheless I hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 09, 2015 | Acer Computers & Internet
Foxconn bluetooth plus edr
Seems that your bluetooth edr is a usb device, it might be made by third company: I found this text
Your Device Info Foxconn Bluetooth 2.0 plus EDR Hardware ID USB\VID_0A5C&PID_2101&REV_0100
Compatible IDs:
USB\CLASS_E0&SUBCLASS_01&PROT_01
USB\CLASS_E0 Version Driver Found Device Type btm Driver Version OS Support 2K,XP,2K3,VISTA,WIN7/32bits
XP,VISTA,WIN7/64bits Driver Date Manufacturer Motorola, Inc. Foxconn Bluetooth 2 0 plus EDR Driver Download for 2K XP 2K3 VISTA WIN7...
Mar 23, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Bluetooth aspire 9420
Please do the following steps...
1. Download the bluetooth driver - 'Bluetooth_Broadcom_6.0.1.3500_VistaX86', its the one for vista but works for win7. After the drivers installed sucessfully the bluetooth still didn't work as the bluetooth hardware wasn't turned on, pressing the bluetooth button to the left of the keyboard didn't do anything for me.
The driver is available from the Acer website below under the Vista section, just click through the categories notebook/model/OS/drivers etc until you reach it.
http://global-download.acer.com/GDHome.aspx?SC=PA_6&LC=en
2. Next download Dritek Launch Manager - 'LaunMgr_Dritek_1.1.1.3_VistaX86' (this utility controls the assignment of shortcuts/applications to the other buttons on the keyboard) from the Acer website above, it'll be under the applications tab instead of drivers.
For some reason the Launch manager zip also includes another zip of the drivers for the Nvidia Video Card, I can't see why they're bundled together but it is Acer after all.
After the launch manager had installed the dedicated bluetooth button worked just fine first press, but bizzarely this application doesn't allow you to assign the bluetooth button, just the other 4 buttons above the keyboard.
But it clearly fixed my issue so it must have installed something which brought the bluetooth button back to life.
BTW the Launch Manager doesn't even have to be running for the bluetooth button to work.
Hope this fixes your issue.
Mar 16, 2013 | Acer Aspire 4720 Notebook
Need 5002WLMi windows7 drivers
Have you tried the Aspire website for these drivers? https://www.acer.com/ac/en/US/content/group/laptops
Acer bought Aspire, good luck.
Dec 18, 2017 | Acer Aspire 5002WLMi Notebook
I have an acer aspire 5684wlmi. it will not connect to the internet. even when a network cable is placed in my Virgin Media Super Hub. it says limited access. i am running windows 7. I have also been...
If your laptop was running windows XP that would explain the problem, when you upgraded to window 7 you found that some of the drivers were not supported. The only option, go into the Acer site, go to download drivers to see if your laptop supports windows 7, if no! contact customer support and the technical department.
Apr 16, 2012 | Acer Computers & Internet
I have aspire 5738G with window xp i am facing problem with blutooth device .i download bluetooh drive from acer website and installed but device is not working .when i click the bluetooh icon this mesge...
I understand that this laptop was not designed for XP?
If that is correct, all aspire 5738G's I have found are Win7
I dare say there is no compatible driver and that is why it doesn't work.
Feb 07, 2011 | Acer Computers & Internet
I changed out the hard drive that came with my Acer Aspire 4530 and put Win7 on it. I see that there is a bluetooth button but when I try to turn it on it never lights up. Beyond that there is no Bluetooth...
Many acer notebooks have a bluetooth button but no bluetooth installed, two of the acer laptops I've owned have had the buttons for the bluetooth, but when pressed a message about No device has come up on both machines. The bluetooth is possible to be added to the machine but not installed from factory.
I'd need to know the exact model from the bottom of the laptop to confirm if it comes with bluetooth or not.
For example. Acer Aspire 1522wlmi
Sep 04, 2009 | Acer Aspire 4530-5889 Notebook PC
Computers & Internet Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
