Question about Panasonic TC-14KM30R 14" TV
Tv 29 philips 29pt4824 - my eht is out of order. what will be the cost and where do I get it? I stay in pune.
Wansa Model 2992 29" Color tv Tansformer is not workiong . coudnt get it in Pune India ?
Yes. Go at the Extreme south end of Pune. I've seen so many transformers there at about 3 years back. Do not take big one. Be care when you travel with so much money. Good Luck.
Sep 19, 2015 | Televison & Video
I want EHT number. i lost my t.v EHT number
If by eht you mean high voltage transformer, Google the model number with "parts" to see what is available or contact Philips.
Jul 19, 2013 | Philips Televison & Video
What is The Cost of The Onida Oxygen Thunder 29 EHT Price In INDIA
Hello
The cost of most of the 29 inch tVs will come between Rs400/= to Rs550/= OK
Sep 03, 2011 | NEC PlasmaSync 42MP3 42 in. Television
I have a 29" Philips TV model 29PT4824/94R. The
To make sure that the external speaker is good or deffective try to use others speaker.If the other speaker work it means that your speaker is deffective and if the other speaker not work it means that the problem is the sound output amplifier or driver of the TV.You need to check the inner part othe TV.The board of the TV inside at the sound section, just fallow the speaker wire to the board,that is the sound section.Check if theres a loose connection.
Jul 16, 2011 | Philips Televison & Video
I have bought the Philips AVENT breast machine (electrical) in UK and have brought it to india. From last four months i was using this machine. Today this machine is giving me some problem while sucking...
Philips service centers in Pune
Pune
M/s Omkar Service
Survey No. 268/6, Balchandra Villa, Backau Wolf Colony, Pimpri Chinchwad Link Road, Pune - 411033.
Tel: 274811
M/s Vrndavan Services
Shop No. 1, Pancharatna D, Pune Solapur Road, Fatima Nagar, Pune - 411013.
Tel: 65212352
Raja Electronics & Services Pvt. Ltd.
Shop No. \5, Iqra Building, 2390B, New Modikhana, Off M. G. Road, Pune - 411037.
Tel: 26431314
May 03, 2011 | Philips Baby Care
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
Apr 21, 2011 | JVC AV-F29MX3U 29" TV
Will not turn on
if LED is blinking then following is the solution.....usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ......if LED is not blinking then.....on main board in power section area some component is deffective.....MAIN BOARD HAS TO BE CHECKED COMPLETELY...... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact philips service centre.........
Apr 20, 2011 | Philips Televison & Video
Switch off with X-RAY error message
That is unusual. The only time a TV screen will stand a chance of emmiting small amounts of X rays is when the EHT exceeds, for a 29" tube, 32KV. The tube normally runs at around 27KV
I would get it checked out and have the EHT measure with an electrostatic meter.
Feb 27, 2011 | JVC AV-K29MX1U 29" TV
Thomson Model no 29 DG91XD EHT PART RQUIRED
hi there.i presume you mean the line output transformer? the part number on the side is what you need ,then get in touch with grandata (uk company) who should be able to supply you with one.or alternatively chs.(chas hyde and sons).the problem now is that a lot of tv spares companies are now geared towards lcd and plasma spares,so its possible it would need to be put on special order.hope this helps, regards, steve
Oct 05, 2010 | Thomson 29DM400 29" TV
Panasonic TC-14KM30R 14" TV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
