Question about Philips Home
I'm trying to connect philips hue light bridge to my airport express from apple. My issue is I have a first generation model which only has one port for the ethernet cord and there needs to be a second port for the philips to connect to.
marked
  • 6487 Answers
SOURCE: DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Posted on Nov 10, 2008
  • 17 Answers
SOURCE: New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Posted on Feb 15, 2009
citroenchris
  • 600 Answers
SOURCE: I can't connect apple airport expresses with a siemens 587 route
When doing this keep your password to 13 characters as different companies apply different defaults to make up the required 13
Posted on Oct 22, 2009
agatha_12301
  • 205 Answers
SOURCE: I just moved to college
check your security settings
Posted on Aug 20, 2011
AndrexT
  • 20916 Answers
SOURCE: Can I use ethernet and wifi together?
No, you can use both type of connection without problem. Ethernet is a direct wired and generally faster connection. Wi-Fi is a via air form of transmission and is highly dependent on how many cellphones and computers are connected at any one time. In airports where I work, this is a big problem. My airport lounge has its own Wi-Fi provided by DataValet for this reason.
When you connect via Ethernet the connection will be used automatically. when you wish to use Wi-Fi, you will choose that in settings. You should only use one, although it isn't going to hurt if your try connecting via both. My guess, is that it will take the best signal.
Posted on Nov 11, 2015
Testimonial: "Thanks mate, makes sense that it would choose best signal but I am having overall connection issues (provider related) and wanted to rule out anything I was doing. Cheers"
How to install canon mp250 printer to ipad2
as this printer has no WiFi function it cannot print directly to an iPad.
however if you have an airport-express router you can connect the printer there with a USB-cable and use it wirelessly...
install-canon-mp250-printer-ipad2-24izmgwjpqkk3mw4hcixslyy-2-0.jpg Canon Support Drivers PIXMA MP250 AirPort Express 802 11n 2nd Generation Guide to ports and connectors install-canon-mp250-printer-ipad2-24izmgwjpqkk3mw4hcixslyy-2-2.jpg
Aug 08, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Can I repair an airport express 802.11n? I bought a broken airport express on ebay ($20 incl. shipping) expecting that the power supply was the issue and knowing that I could cut the thing open and work...
I am suppose to add the solution here but unfortunately i am here to explain the problem. I got the new Airport Express. I have HP Pavillion and running with Windows Home VISTA. I tried almost here and there everything which is mentioned on forum. But it is not working.Laptop can connect with router but router is not getting connected with Internet. It's always displaying local access only which is killing me. I will try to give one more try to this setup otherwise i need to return this **** and get something else.
Sep 20, 2011 | Apple AirPort Express Base Station with...
I am using the airport express to play itunes through my stereo only. I unplugged the unit to move it to a more convenient place and now I cannot to get it to work. It was working well before. I...
From my reading at the Apple support web site, it appears that you may need to download the latest version of the Airport Utility in order to get around this issue.
Additionally, Apple has just recently come up with an update to the firmware for this device.
Try downloading the latest version of the Airport Utility (Mac or Windows) and see if that doesn't resolve the issue.
After installing the latest version of the Airport Utility, try to connect to the Airport Express. If that is successful with the new version, click the "Manual Setup" button to display the "Summary" page for the Airport Express.
Next to the entry for "Version:" there should be a button to press to upgrade the firmware to the latest version (7.5.2). Perform the upgrade by following the on screen directions.
After the upgrade, again attempt to connect to the Airport Express using the Airport Utility. This should work as expected.
Before attempting to use the AirTunes (recently renamed "AirPlay"), make sure that you have the latest version of iTunes installed.
Dec 27, 2010 | Apple AirPort Express Base Station with...
I'm having trouble finding a reliable software to download that will enable me to play youtube/slacker/pandora (non- itunes music) on my Mac and listen through my stereo using my Airport Express,...
Welcome to Fixya community.
Please try download and Install MacTube Player to play Youtube video or music... Let me know the result please...
Also to play the music in stereo receiver please follow below steps.
  1. Plug in the Apple AirPort Express into a power outlet near the stereo. Connect an audio cable from the audio port on the AirPort Express to the audio in port on your stereo. If your stereo has a different sized audio port than the 3.5 mm one on the AirPort Express, you will need to use an adapter to connect it.
  2. Plug in an ethernet cable from the AirPort Express to your computer or wireless router for a wired connection. For a wireless connection, connect the AirPort Express to your existing home network, or use a computer with a wireless network adapter to connect directly to the AirPort Express.
  3. Connect to the AirPort Express with your computer as directed in the manual to run the setup with the AirPort utility. Follow the instructions on the screen.
  4. Open iTunes and play the music to your stereo. There should be a pop up in the lower right corner after you run the Airport utility.
Let me know how far you could able to reach in a result. Our expert friends are here anytime to solve your issue.
Thanks once again for joining us.
Have a good day.
Aug 02, 2010 | Computers & Internet
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Home Logo
288 people viewed this question
Top Philips Home Experts
john h
Tom Chichester
Are you a Philips Home Expert? Answer questions, earn points and help others
