Question about Hunter Dryers
The light wont come on from the switch just the pull chain
    Genius:
  • Hunter Master
  • 1,617 Answers
Turn the light on from the pull chain, THEN USE THE WALL SWITCH TO TURN ON/OFF
Posted on Oct 20, 2013
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
I thought I put the wires from the old switch to the new switch correctly but now the fan does not work. The lights come on but no fan.
The pull chain for fan and the pull chain for lights are wired separately.
If you are talking about a wall switch, add a comment with clear description of old switch and new switch, screw colors on each switch, and color of each wire for possible help.
Open following link possible illustration of your pull-chain fan switch.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#fan-switch
Jul 27, 2011 | Westinghouse Electric Westinghouse...
Why won't my remote for my light on the Hunter fan work? The light also will not come on when I pull the chain.
I usually discuss this exact problem with customers that have a DIY ceiling fan. First; If you just installed this fan you noticed that there are several switches on the fan and on the remote, there is also the switch that originally controlled the ceiling light fixture (If it is a dimmer switch, it MUST be replaced with a single pull switch). All of these can be set wrong. Make sure the circuit breaker is not "tripped."
To start easy; assure that the wall switch is on, (leave all the "pull chains" alone, for now) Check to see that the remote has fresh batteries. press the light switch (on the remote, if it is a dimmer type set it to high, press it several times. If this does not work leave all the switches where they are and pull the light chain once, and again try the remote for the lights only. Hopefully that worked. Now do the same for the fan, press the remote once (on any speed) If that does not work pull the fan chain once try the remote again pressing the same switch, that should work. Now that you have it working remove all the pull chains, so it won't get "confused" again. Good luck!
Feb 09, 2011 | Hunter 27185 Remote Control
Can't Find Correct Pull Chain Switch I have a new bathroom wall sconce that has a two lights - a regular bulb and an LED night light. The pull chain switch for it broke and no one at Lowes or Home Depot...
It's called a "momentary switch, normally closed". This is sometimes abbreviated Mom Switch, NC. But I have never seen one with a pull chain before. Maybe you can find one with a toggle that you can attach a chain to.
Good luck.
May 06, 2010 | Electrical Supplies
The pulley chain broke on the light on my ceiling fan and there is no slack to turn the light on or off. Can you please tell me how to fix or replace pulley?
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
Jan 20, 2010 | Solar 2-wire Pull Chain Light Switch For...
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
Pull chain
this is the type of switch that attaches to one wire only do you understand?if connects to live wire to break the conection.
thank you for useing fixya
Please turn off main befor fix
RATE ME
Apr 20, 2009 | Solar 2-wire Pull Chain Light Switch For...
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Jan 21, 2009 | Solar 2-wire Pull Chain Light Switch For...
Dryers Logo
19 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
