Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have scag rider and when I engage the blade the 2 fuse blow out?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Unplug the clutch and see what happens... if it doesn't blow then you need a need clutch. if it still blows check the ignition switch and the pto switch... oh, next time include at least a model # so know what model of scag you have. multiple style electrical systems throughout the years...
Posted on Oct 20, 2013
Mower blades still engaging with broken pto clutch wires, why?
looking at the unit
could be the design of the clutch
fully engages when no power
http://www.scag.com/clutch.html
May 12, 2016 | Husqvarna Garden
I ran out of gas while mowing now my blades won't engage, what's my problem?
Sounds like you have 2 separate problems.
Once you get more gas and get the engine running you will have solved the first one.
If the blades will still not engage, shut the engine OFF and check the drive belts, idlers, and spring on the tension idler.
Sep 19, 2015 | Scag STT61V-35BVAC-SS Gas, Hydro Turf...
Why will the cutter blades on scag SW36A not engage?
I am thinking this is a 12 volt PTO system that does not have a battery... this is where you need to check the wiring, especially the big white plug on the right side of the mower... It might also be a mechanical engagement system, if this is the case, suspect the belt popped of or is way out of adjustment
Sep 12, 2014 | Garden
Engine cuts out wen blades turned on
You either have a faulty PTO switch or a faulty seat switch
The saftey shut down circut usually has four switches that have to be made to start motor and engage blades
both steer levers have one each
seat has one
lever conected for parking brake has one
scag might use plug in relays which could be bad too
Aug 09, 2014 | Scag SVR61V-801FX V-Ride Hydro Stand-on...
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
Blades will not engage but will remain running
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Apr 05, 2013 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Husquevarna rider mower dies & blows fuse when pto is engaged
you may need to check that your blade engage sensor is working properly, and that the one on the seat is working properly. if not that, then check the ignition fuse connections. they may seem to be connected properly, and still not be seated properly. good luck.
Nov 20, 2011 | Husqvarna Garden
Blows a fuse when i engage the mower blades
assuming that your rider has an electric clutch? if so then it is prob shorted out,,,,,,,you can check the clutch with an ohm meter readings should be 2-4 ohms any less means that it has an internal short anything more then it has an open circuit
Nov 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
188 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
