Question about Kenwood Audio Players & Recorders
I have a kenwood ka-94 and it still plays music but if I turn the volume up the speakers start making a popping noise and the speakers are not the problem so I need to know what the problem could be internally
    Problem Solver:
  • 13 Answers
It does sound like your speakers. But it could be the output transistor are going bad. As you increase the volume causing more current to go thru them it make a clipping sound. If you have a different set of speaker try and see if the popping is replicated. If not have some check your receiver out.
Posted on Oct 22, 2013
  • 143 Answers
SOURCE: guitar amp make large crescendo-like noise, loud pop at end.
Same loudness, no speaker? This sounds (no pun intended) like a filter capacitor shorting out. Open it up and VERY CAUTIOUSLY look for what is making the noise. Filter capacitors can eject hot stuff. Very dangerous.
Posted on Jul 23, 2008
  • 4234 Answers
SOURCE: amplifier will only put out "faint" music, etc, even when the volume is turned all the way up
This may sound silly, but please check to be sure that the tape monitor switch in not engaged. Update this if that is not the problem.
Dan
Posted on Oct 01, 2008
  • 150 Answers
SOURCE: I use an azur intregrated amp 540A and a Azur Pre
I've never repaired one of these but I have an amp at home that makes a intermittent static "popping" noise that i'm going to put down to a dirty volume pot (control) that needs cleaning. I will also have to change some of the electro capacitors that have dried up inside which cause "shot noise". With the right lubricant (electrical contact cleaner, nothing else) you could take to lid off and spray a small 1 second blast into the hole of the pot and any other balance or tone control yourself but I would take it to the electronics repairer to get the capacitors checked over.
My theory only
Good Luck!
Posted on Jan 17, 2010
technical114
  • 1851 Answers
SOURCE: I have a Marantz 2270
This kind of problem is logical, if you have the "loudness" control enabled. Well, let me explain the situation. The loudness control is a function that boosts the lower and higher frequencies (the bass and treble) in low volume settings. This is useful because at low volume settings our ears are not so sensible at these frequencies, so the result is nice to hear. This boost (the loudness) stops automatically (at most amplifiers) at volume settings just above the middle of the volume control (to be more specific near the 1 hour setting of the volume knob), that's the point that you get this cracking sound. In case the audio source has plenty of bass frequencies the result is what you hear.
I suggest you to lower the bass boost potentiometer or disable the loudness control when you hear music at these volume levels. A good idea also is to disable the loudness control permanently and boost the bass and treble from the knobs as you wish. This will give you a sound near the original one although at the beginning you will feel the absence of bass (this is because the sound you were listening before has more bass).
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Mar 19, 2011
SuperTech-11
  • 1591 Answers
SOURCE: When i am turning the power on at. channel 1 for a
Pictures would help a lot (of the circuit board)
You're lucky, you have a whole channel for reference!
This means we can troubleshoot by metering points at channel A and cross referencing them with what's happening on channel B (You'll need a multimeter and SOME skill, as well as a soldering iron, solder, desoldering braid and/or a desoldering pump)
When we find something that's way out of spec, we know we've found the issue, or at least something connected to the issue.
If you have an oscilloscope, we can trace the signal to the point that it stops.
If not, as I said, metering mirrored points should lead to the issue.
Posted on Apr 09, 2011
Marantz 1170 was playing music and started turning up volume all music shut off what's the problem
how old is that unit ?
cant find a picture of a 1170
faulty volume dials or slides
internal fuse ?
power source over heating
just how load = enough to pop the speakers
Apr 16, 2017 | Marantz Audio Players & Recorders
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
My Kenwood KA-128 wad playing One Night and just tienes off. When I turned it back on, the only light that came on was a red doyt on the volume control knob.
Make sure you have +12 volts on both the red and yellow wires as well as a solid ground. If that is the case then disconnect power and wait about 5 ninutes...this will cause a hard reset. If it still doesn't turn on try disconnecting all speakers...if it still won't turn on the unit is defective...if it does then reconnect each speaker one at a time ubtil it shuts off...then you know you have either a bad speaker or a wire issue with that speaker
Aug 28, 2016 | Kenwood Audio Players & Recorders
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
May 10, 2015 | Kenwood Audio Players & Recorders
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
Amp is connected to speakers but the volume coming out of the speakers is very very quiet. Speakers have been tested seperately and are known to work. Have turned the input sensitivity to max, this makes...
sounds like you need to turn up your gain and bass. while amp is on and your favourite music playing, turn up the diles on your amp until you get the sound you want one by one.
Feb 28, 2011 | Kenwood KAC-529S Car Audio Amplifier
Speakers are popping
you may have a bad cord to your speaker or a bad rca cord ive had some what the same thing it turned out too be a bad groung on the rca cord
Nov 29, 2009 | Audio Players & Recorders
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
Indicator light not working and humming noise
your circuit board is bad not repairable i have the same prob but not kenwood they said it would cost more then its worth.
Jan 03, 2008 | Kenwood 103SW Speaker
141 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
