Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Top is locked and won't open - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Sergeant:
    Champion:
  • 257 Answers
Try to unplug the power cord about 5 minutes then re-plug to see if the problem solved. If it does that again, there is something wrong with this unit. It should have the error code appears on the display.
Posted on Oct 22, 2013
Whirlpool microwave won't open
Possible that the door switch is broken or jammed,. You need to remove the top cover, open the panel and remove the door and switch , check for broken plastic or lock, If so use glue to stick and reset.
Jan 24, 2013 | Microwave Ovens
LG WD1470FD won't open
You will need to replace the door lock assembly. If remove the top, you can reach down and manually open the door. Below is a video to show you how to replace the lock. Here is the lock to order.
Dec 04, 2012 | Washing Machines
My washer is locked won't open
Will Not Unlock
• Press off. The motor control is not responding if it
takes 4 minutes to unlock. The motor control is
either bad or disconnected.
• Unplug and reconnect power cord. Wait 20 seconds
for machine to unlock.
• Check lid locked switch circuit. Circuit should be
closed at machine control.
• Check for loose electrical connections at lid lock and
at machine control board.
• Push lid closed to make sure nothing from inside is
pressing against it which may keep it from unlocking.
• If necessary, remove clothes by disconnecting power
to washer, and open top cover with a putty knife.Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | Maytag Neptune FAV9800AW Top Load Washer
Rear passenger door won't open.
the latch rod has came off you will need to remove the top of the door panel to get access to it to open your door
Jan 03, 2012 | 2000 Ford Expedition
Locking mechanism
replace the lid lock ! its a safety measure. I would not recommend removing or bypassing lid lock. just replace it. without the lid lock it will work with lid open. good-day ! if you really what to bypass the lid lock. Find the wire that goes to the switch. Splice the wires together and the machine will think the lid is shut all the time. if you can not get top of washer off. just call an appliance center and give them the model and serial number. and they should be able to tell you. good-day !
Dec 13, 2011 | Kenmore Washing Machines
I lost Power from a Thunder Storm and now my Whirlpool Cabrio top loader won't open
Thats sounds as if the lock asm is stuck. As soon as the power went off the lock would have de-energized and should have opened.
Too check the lacth for sticking open the top by placing a putty knife in the seam between the top/front cabinet panel at the corners and push in to release the clips that hold the top to cabinet then raise top and see if something appears to be stuck on latch asm.
Gene
Aug 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Remote wont open door. locked out
Remove emergency key blade from top of remote
Open door manually
It just clips out
It will show you in owners manual,but that is in the car it won,t help
Sound like flat battery, if so key won,t turn untill you charge it
Feb 03, 2010 | 2007 Mercedes-Benz SLK-Class
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
