Question about Pentair Pool & Spa
LED panel on heater does not light up and water temp reads higher then actual 107/64 degrees on control panel
  • 717 Answers
This is an indication of a bad water sensor. It also tells me that the pressure switch may be bad because if it is working then the light on the panel will light up telling you that the spa water is heating.
Rod
US Parts Center
Posted on Apr 14, 2014
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: Raypak RP2100 not showing even close to correct pool water temp.
Bad thermistor probably. It is not a very expensive part.
Posted on Jun 14, 2009
  • 990 Answers
SOURCE: water temp. reading isn't the the same as the
If you have drained the spa latly and refilled you could have an air lock keeping the heater dry. Simpley find the drain valve under the spa and open it till it run's water. This should help the problem by letting the pressure even in the pipeing and flooding. Good luck.
Posted on Mar 11, 2010
adamh294
  • 310 Answers
SOURCE: my hot tub control panel keeps showing OH and the
It sounds like your circulation pump is not keeping up with the heater. Check for debris in the pump impeller. If this is 24 hour circulation pump, it is probably failing. New units are about $200 US
Posted on Oct 28, 2010
Master Temp 400 reading 32 degrees on LED read out and the remote control is reading 62 degrees. What can cause the difference?
The control panel has its own temp sensor which is a probe into your plumbing. It's typically found between the pump and the filter and is held on by band clamps.
The heater has its own temp sensor found on the header manifold area.
i doubt the water is 32 degrees so I assume the heater temp probe is bad, it needs to be replaced, it's plugged into the circuit board and threaded into the header of the heater.
The two sensors should match or be within one degree of each other for ideal operation.
The reason they have separate temp sensors is to protect the system.
Nov 26, 2016 | Pool & Spa
Heater will not come on.
controller temp sensor bad
Jan 06, 2013 | Pentair Mastertemp Heater
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pool & Spa Logo
52 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
