Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
BOSH Model: SGS43E72EU/73 My dishwasher incoming
BOSH Model: SGS43E72EU/73 My dishwasher incoming water solenoid valve (at the beginning of the flexible hose) never stop! so when the water is to high the safety switch located on the side is switch ON and the water drain /go IN no stop. Which sensor give the signal to the S.Valve to Switch ON/OFF? Any schematic electrical diagram to check how is work? I already check the functionality of the incoming water Solenoid valve located at the beginning of the flexible hose (220 V supply water go in & stop supply, water stop) TKS for your Help Jacques
3 Suggested Answers
  • 414 Answers
SOURCE: Water supply to my Bosch SHE43CO5UC/17 dishwasher
Could be a dirty hose filter or faulty inlet valve. Ther could be a leak and the bottom of the unit has flooded activating the flood safety which will cut the water supply. The pressure chamber and/or the hose pressure chamber to sumo could be block (take of left side panel and these are at the bottom right). Finally, the aquastop (grey box connected to the mains water supply that feeds the d/w) could be activated, faulty or fitted in the wrong position
Hope this gives you some where to start..
Posted on Jul 09, 2010
  • 3247 Answers
SOURCE: Got a lound buzz type
You may have dislocated the connection that controls the AquaStop circuit.
This is linked to the inlet hose. Either the connector linking the inlet tap to the inlet valve is loose or the float switch has triggered.
Check the diagrams on this site. The float circuit is shown in the base assembly.
I hope this helps. In case you want more details I will need the full model number of the dishwasher. The 5-6 additional characters after SHU53.
Posted on Jan 25, 2011
How do i fix e5 on the dishwasher
Three common causes.
  1. Defective solenoid water inlet valve
  2. Plugged water inlet filter
  3. Defective stop valve located where the inlet hose connects to the water line.
Problem 1 usually no water will enter. It usually works or not.
Problem 2 and 3 the situation is the tub begins not to fill and over time the filter closes completely or the stop valve plugs completely.
If you open the door after the fill cycle and you have not heard the unit fill it is most likely the fill solenoid. Partially filled need to look at the stop valve. The rubber washer of the valve deteriorates and loosens relocating over the hole plugging the water from going through. When you try to shut off the valve it in most cases will not close water tight. You can replace the stem and washer if you can find the same hardware type.
The solenoid replacement can usually be axcessed from the front but requires a skilled technican.
26051739-3tozjaopshvuyndb2zxhmboi-4-0.jpg Solenoid valve below
26051739-3tozjaopshvuyndb2zxhmboi-4-2.jpg Hope this helps?
Jan 13, 2016 | Dishwashers
Bosch dishwasher trouble shooting
check the incoming water line cor contaminte blockage..if possible use compressed air to blow it clear if blockage is present..some use a screen filter in the water hookup.. check this also..
Jan 18, 2014 | Dishwashers
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
Kenmore Model 16798 dishwasher: no incoming water throughout entire cycle
Hello there
The solenoid is just a valve. Only it operates electrically.
Check to be sure you are getting water to the valve. Turn off water,
disconnect water supply from solenoid valve, place line in bucket, turn on
water slowly.
Does water come out?
If yes, then reconnect water and check other side of valve. Disconnect
connection on other side of solenoid valve. Does water come out when you
cycle dishwasher?
Could be a problem with plugged water tubes. All sorts of junk comes out of
water lines.
Also if you have a manual valve on the wall for line going to dishwasher,
the line could be plugged at this valve. Turning it off/on several times or
backflushing might clear the plug.
Mar 04, 2011 | Kenmore Dishwashers
I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
Hello there:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jul 08, 2010 | Microwave Ovens
Water won't shut off, flooded kitchen
Check inlet water solenoid valve. May require cleaning. It's stuck and in open position or due to valve not getting seated properly inside valve body. Check incoming water pressure. If too high a pressure, this can happen.
It is advisable to close the inlet pipe **** after the days work.
May 28, 2010 | Whirlpool 24 in. GU940SCG Built-in...
My bosch excell dishwasher won't drain it stops during the wash and won't restart until I have emptied the water then it will wash ok until it gets to the drain part of the programme then it stops again....
Mar 22, 2010 | Bosch Dishwashers
No water coming into dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 06, 2009 | Whirlpool Dishwashers
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
43 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
