Question about Siemens Vz151hfb Hepa Filter For Vs08 Vacuum Cleaners
How to collect the cord in vacuum siemens vs08
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
Don't understand, you want to collect the cord....and do what?
Posted on Oct 21, 2013
Siemens Ruby S227i vacuum cleaner manual booklet
Try Googling (Siemens)(S227i)(manual) without parens.
Apr 21, 2017 | Vacuums
Electolux hoover 1600w power plus wont start
John, first off, you have a Hoover upright vac, not an Electrolux. If it won't start, check cord to be sure it's plugged in properly to a live socket, then find and push reset button, frequently found near the corner on the rear of the base. (Small red circle). If that fails,. then you need to take it to the nearest repair shop for diagnosis.
Nov 02, 2013 | Hoover Platinum Collection Upright Vacuum
Bissell vacuum shut off and will not turn on again
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest referring to your manual on how to replace the power cord or contact Bissell for troubleshooting steps. 1-800-237-7691.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 15, 2012 | Bissell 37604 Lift-Off Pet Bagless Upright...
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    How do you disassemble the handle to replace the power cord. I've removed the handle from the body of the vacuum, but don't want to break any plastic covers trying to pry them off to access the power cord...
    bad news to you.(don't get mad at me please). 2 prong means is a "DOUBLE INSULATED" vacuum. any electrical repairs are not recommendable other by a shop because after repairs they have to test for grounding with a special meter to prevent electirical shocks. for that reason I personally can not give advice on how to do it. if you want to take the risk, well.... good luck to you. I do this for your safety and ours. I hope you understand my position.
    Feb 09, 2011 | Hoover Platinum Collection Upright Vacuum
    Clogged sweeper filters changed and hose cleaned, but no dirt collecting in the bag. I am no sure what do do next
    You have a rubber flap in the dust collection bin that may have been pulled out causing the collection bin to close when vacuum tries to pass through. Try pushing the flap back in to see if that's the cause of your vacuum loss. To test if this is the cause try turning the cleaner on and feel the outlet leading into the removable bin to see if there is any air flow. If there is no air flow, unplug the vac and run a coat hanger through the inlet tube to find and clear any obstructions. Then take the vacuum outdoors, plug it in and turn it on to clear any dust or debris left in the vacuum chamber.
    Mar 15, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
    My Bissell vacuum cleaner won't turn on.
    One of the possible causes that your Bissell won't start is that power cord may not be firmly plugged in so you may need to check electrical plug. You may also want to check or replace the fuse or reset the breaker in case there is blown fuse or tripped breaker.
    Ava B.
    Dec 29, 2009 | Bissell 6594 PowerForce Bagless Upright...
    Dirt does not collect in container....collects in filter area
    Small Filter at bottom of cannister may be clogged. Not letting enough suction draw dirt down.
    Dec 22, 2009 | Eureka 5856BVZ Boss Bagless Upright...
    Siemens Vz151hfb Hepa Filter For Vs08 Vacuum Cleaners Logo
    150 people viewed this question
    Top Siemens Vacuums Experts
    JoeVacs
    Are you a Siemens Vacuum Expert? Answer questions, earn points and help others
