Question about GPX Dpi Dh300b Dvd Player
I bought this DVD player and when I put a DVD in it it starts to load but then says "bad disc" I have tried several different dvds...
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
SOURCE: GPX D1816SIL
TAKE IT BACK TO WHERE YOU GOT IT-----THEY ARE JUNK!!!
Posted on Dec 16, 2007
  • 86 Answers
SOURCE: I have a problem regarding my D1816 dvd player
Put in an audio cd and see if it will play music. If it does, you may be able to get a dvd/cd cleaner and run it to clean off a possible dirty lens.
Posted on Jan 26, 2008
  • 16 Answers
SOURCE: dvd player bad disc message
your dvd head (lens) is bad
(1) it needs to be cleaned by a special fluid puted in the cleaning disc or
(2)it needs to be adjusted because it lit vey low illumination (light) during detecting the details of the disc. and this need a qualified technician ot adjust the variable resistor port attached in the lens assembly unit.
Posted on Sep 08, 2008
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Foreign disc messed up portable dvd now it wont play british dvds
Croikie!!!
See if there's a factory reset option in the menu
Also,try cleaning the laser lens with 90% alcohol and a swab ( Gently) then buff it dry
Apr 19, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
The machine keeps stating bad disc, for all dvds. We have the GoVideo DVD VCR combo... we tried playing several different dvds and the machine keeps coming up with "bad disc".
It could just be dirt on the lazer/lens. Try cleaning it with a good brand name lens cleaner for DVD/CD. If that doesn't do the trick there might be damage to the lens, or an electrical fault.
Jan 04, 2010 | GoVideo Go Video DVD/VCR Combo
No disc
I will assume you have tried several different DVDs. Try a CD also. I have found that this is caused by either the laser eye needs cleanning or has gone bad. Try cleaning the eye gently with a clean/dry Q-tip. Otherwise, the laser drive will have to be replaced.
Dec 30, 2008 | Durabrand PDV-705 Portable DVD Player
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
GPX Dpi Dh300b Dvd Player Logo
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
