Question about Ovens
Wiring Oven & grill diagram
I can have the oven & grill on then without warning they both go out & it can be 1 minute or as long as 10min before they come on.Sometimes the clock is still on most times it is zero.. help evening meal can last forever & partner is determined to fix it himself!!!
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 10 Answers
SOURCE: GE Profile Performance Double Oven
I had a similar problem,  try the fix belowhttp://www.fixya.com/howto/h155060-dreaded_f7_error it may work.
Posted on Aug 20, 2008
  • 1462 Answers
SOURCE: delonghi esf461st oven not heating up
grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
Posted on Sep 06, 2008
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
danforddan1
  • 192 Answers
SOURCE: wiring diagram blodgett sho-e convection oven
I dont know much about Blodgett ovens other than how to bake in one and that are top of the line. I use to live next to the factory where they are made. On beautyful Lake Champlane Vt. Go here http://www.blodgett.com/convection_full.htm
you can contact them by phone.
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-018
how about that. please rate me Thanks
Posted on Apr 22, 2009
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Main oven selector switch wiring diagram
Nice pic Norman but without the make & model we are spinning our wheels!
Jan 08, 2015 | Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Technika oven manual - mod B50STIP/1
I have a Technika B50 STIP /1 Oven and the Oven Function Selections have warn off. I mostly use the conventional cooking ) at 7.00 oclock on the dial) I cannot remember what is on the dial at 5.00 oclock? as it has worn away.
Help please
Liz
Aug 05, 2012 | Ovens
The oven keeps turning its self off
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Mar 06, 2011 | Stoves 720EF Electric Double Oven
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Delonghi esf461st oven not heating up
Sep 06, 2008 | Ovens
Nov 04, 2007 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
