Question about Panasonic Microwave Ovens
Panasonic nn-sd277. the only thing that seems to work is the clock and the timer. If you try to get it to work there is snap and it quits. Ours was made in may of 2010 and purchased shortly after that
    Top Expert:
  • Panasonic Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Posted on Oct 21, 2013
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
  • 52 Answers
SOURCE: NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Posted on Feb 21, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: i have a panasonic slimline combi NN A554W which
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Posted on Oct 06, 2009
joust
  • 7 Answers
SOURCE: Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Posted on Jun 02, 2010
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Oven door on PanasoniPanasonic microwave Model NN-SD277 won't open when pressing open button
I just had that problem. It is the plastic workings. One of the plastic posts that holds the pivoting lever had to be epoxied. That plastic rejects crazy glue, don't waste your time. Just epoxy and as much as you think can fit under the electronics and the metal plate you will have to pull out.
My suggestion is take pictures of every step so that you can hook all the electrics back up. There are some testy switches that must be unsnapped too.
www.ianklepsch.ca
Oct 08, 2012 | Panasonic Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Microwave Ovens Logo
120 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
