Question about Ovens
Magic Chef Oven won't light
My Magic Chef oven won't light. Lately it has taken much longer to turn on (as long as 4-5 minutes) but I didn't think anything of it. Today it wouldn't light at all but filled the kitchen with gas. Tried it one more time: saw a yellowish light towards the back of the oven, but again, smelled gas & turned it off. My husband is fairly handy with fixing things & we were wondering if this is something we can fix or if we need a service call.
  • 1 more comment
  • ko220 Oct 02, 2007
    Piranha: Your solution is exactly what the oven repair guy said was going on. He is coming today to replace the ignitor. Hopefully, that will solve it. He said it's better to fix an old oven than to get a new one, since they are making the new ones cheaper. I don't know about that, but it's definitely cheaper to fix ours! And with regard to the second question by SusanP: I don't know anything about ovens, but yours sounds very dangerous. I'd get it looked at right away.
  • Anonymous Nov 18, 2007
    my oven wont light,i see a little glow at the bottom of the oven but still no fire
  • ko220 Oct 13, 2008
    Hi, cwsimon74:
    It was about $135.00, which was a good price from a reliable independent stove guy. When I researched getting a new oven, in order to get a nice one with all the features I already have, I was getting into the $750-$800 range. The guy came and fixed it - took about 30 minutes, and it's working better than ever a year later. One little note: you might want to have your vacuum ready for when he pulls the oven out to fix it. That's a place I never clean, and you'd be surprised at the stuff that falls back there!!! :)
  • 114 Answers
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Posted on Sep 27, 2007
I have the same prob!!! what did it cost to have the guy come and replace the ignitor???
Posted on Oct 12, 2008
SOURCE:
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
How do i light a old magic chef stove
If the stove is the one that I think that it is... you will have to lift the cover and then between the burners there will be a small orifice that you light... the pilot light will then light the burners when the gas is turned on to them...
heatman101
Jan 16, 2011 | Magic Chef 9122 Gas Single Oven
Magic Chef: 9122: ingniter works and turns oven on BUT after a few minutes it turns itself off and later it turns itself on again and so on. Igniter problem or thermostat problem?????? Thank you for your...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 11, 2010 | Magic Chef 9122 Gas Single Oven
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
My oven won't work
Replaced ignitor on mine, fixed it.
Nov 18, 2007 | Magic Chef 9122 Gas Single Oven
Ovens Logo
2,790 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
