Question about Garden
Engine valve adjustment
SUZUKI V140X
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Majority of small engines use about .004-.006 in ( .10-.15 mm ) for valve clearance. If you need help actually adjusting them. You need to invest in a manual.
Posted on Oct 22, 2013
Valve clearance on suzuki vitara 1999 1.6
  • Set the engine to Top Dead Centre (TDC) of the compression stroke for the cylinder to be adjusted.
  • Check the valve clearance. The valve clearance specifications are as follows:
    Intake valves: 0.005-0.007 inches (0.13-0.17mm) Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  • After adjustment, tighten the lock nuts to 11-14 ft. lbs. (15-19 Nm).
  • Repeat for each valve to be adjusted.
  • Feb 16, 2017 | Suzuki Cars & Trucks
    Using a feeler gauge what would you set your exhaust valves to on a 2003 Suzuki gz 250
    Hi, Wayne valve clearance (when cold): IN. : 0.03-0.08 mm (0.001-0.003 in)
    EX.: 0.08-0.13 mm (0.003-0.005 in) For this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
    Motorcycle Valve Clearance Adjustment
    Valve adjustment for the GZ250 Page 3 GZ 250 Forums
    Suzuki GZ250 Service Manual
    OEM parts for Suzuki
    Suzuki GZ250 Owner Manual
    Dec 08, 2016 | 2003 Suzuki GZ 250 Marauder
    Need valve lash specs for 1980 suzuki dr400
    Suzuki DR400S - Motorcycle Specs
    www.motorcyclespecs.co.za/model/suzu/suzuki_dr400s%2080.ht
    1980. Engine. Air cooled, four stroke, single cylinder, SOHC, 2 valves per cylinder ....Valve adjustment can be done without a feeler gauge and the CDI has ..
    Dr400 valve adjustment 1 - YouTube
    ? 2:08
    www.youtube.com/watch?v=BH-KFrpwo3w
    Nov 19, 2010 - Uploaded by obtrailriders
    Dr400 valve adjustment 1. ... Suzuki DRZ 400 Valves clearance check \ sprawdzanie luzu zaworowego PART 2 ...
    Nov 01, 2015 | Suzuki Cars & Trucks
    How I adjust valve on 96 Geo Metro 3 cylinders?
    You need to replace the valve came bearing for that valve if it's a Suzuki 1.0 engine. Easy to do.
    Feb 12, 2015 | 1996 Geo Metro
    How to adjust valves on 2002 suzuki car Grand Vitara XL
    no engine, stated. no joy.
    sorry.
    some have 3 engines that year.
    the 2.0 and 2.5L are all HLAs and there is no lash
    but you said, valves, adjust what> do say what.
    time the cam.? we cant guess what you are doing
    why not just flat say so.????
    eg.my valve covers are ticking ? or the cam cover, or what.
    use a $5 stethoscope and listen and no more guessing where.
    Jul 08, 2014 | 2002 Suzuki Vitara
    I have a pecking noise , a mechanic said my intake valve needs to be adjusted. Could you tell me where thats located on a 2005 Suzuki Katana
    Located under the cylinder head cover. There are eight rocker arms. Each rocker arm has two adjusters, 8 for intake and 8 for exhaust. The intake adjusters are at the carb side of engine, the exhaust adjusters are at the front of the engine. Please rate my answer. Thanks.
    Sep 13, 2010 | Suzuki GSX 600 F (Katana Motorcycles
    Valve Clearance
    valve clearance, with engine hot, intake valves are .005-.006 in, exhaust valves are .011 in, if engine is cold then its intake .009-.011 in and exhaust is .007. hope this helps good luck.
    Nov 28, 2009 | 1989 Suzuki Swift
    Is valve adjustment a part of normal maitenance on Suzuki Esteem
    When you hear some tapping, that's why you need -valve adjustments. At 137,000miles you probably need more than that to continue your trouble-free drives.
    Nov 12, 2009 | 2000 Suzuki Esteem
    Garden Logo
    53 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
