Question about Maytag Neptune MAH5500B Front Load Washer
Belt drive for mah5500bww year 2000 style 47909216
Need belt drive year 2000 mah5500bww style 47909216 can you advise
    Top Expert:
  • Maytag Master
  • 34,255 Answers
You can try obtaining the part either from Maytag or an appliance parts supplier
Posted on Oct 20, 2013
Toyota corrollareg 2000 1332 liftback has 39000 miles only do not know if it is belt or chain does it need changing
I would say no and most likely it is a rubber belt...and most cars now can go over 100,000 miles not a problem but it depends on the driving style jack rabbit driving may need quicker attention of 50,000 miles or so.. but check your owners manual and you know your driving style...good luck.
Feb 10, 2014 | Alternative Engines Volume 3
2000 dodge caravan ps pump went out can i drive it?
I would not advise it, your serpentine belt runs all of your accessories, if your pump locks up it will burn your belt up and then you are stranded.
Apr 21, 2013 | 2002 Dodge Grand Caravan
How many years or miles should a timing belt be changed on a 2000 V8 Tundra ?
Replace the timing belt at 90,000 miles or 10 years. Considering it is already 11 years old, replace it now. Warning: This is an interference engine. If the belt breaks you will have serious internal engine damage. The water pump is also driven by the cam belt so it is advisable to replace it at the same time you replace the cam belt in order to save labor cost later on when the pump fails. The pump will not last 180,000 miles so replace it now.
Feb 06, 2011 | 2000 Toyota Tundra
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
A technician stated my alternator belt has a slight crack...how long can I continue to drive with the crack
Nobody can tell when that alternator belt will snap, but the crack means its time to change it.
For precautionary and preventive maintenance purposes, the mechanic just advises you to change that belt before it will snap in the middle of nowhere.
If I were you I will follow the advise!
Hope that clears all the doubts!
Thank you for using Fixya!
Dec 08, 2010 | 2000 Mitsubishi Montero Sport
My Maytag washer is about 15 years old. Suddenly
Without a model number, but with the age, I can only assume that this is a Dependable Drive wash system.
This system utilizes a drive belt and a pump belt and it is recommended they be replaced together after every13 years of normal use. They are very simple to install with no teardown or tools needed. The belts have installation instructions printed on the package.
1. Drive Belt
http://www.repairclinic.com/SSPartDetail.aspx?s=t-a612-%3d%3di437301&PartID=437301
2. Pump Belt
http://www.repairclinic.com/SSPartDetail.aspx?s=t-a612-%3d%3di437300&PartID=437300
The pump belt must be adjusted to the tension requirements written on the package. See link below.
http://www.affordableappliance.com/Tips/Maytagbelts.htm
3. Parts breakdown/disassembly procedures.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
Other issues could also cause the same symptoms but the belts at this age is the 1st suspect.
Aug 30, 2009 | Washing Machines
Very loud spin cycle
The link below, courtesy of www.repairclinic.com, shows that the rear bearing comes with the outer tub only and is very pricey! I have been unable to find a service agency that offers just the bearing. Very aggravating. www.maytag.com would be a good place to define your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MAH5500BWW-%3d%3di1119942&PartID=1119942
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Belt Tension
If you are sure the belt is slipping, you need to replace the belt. Mine was making a growling noise that sounded like it might have been a slipping belt but it turned out to be a motor drive problem. I fixed mine with a motor/control board kit (ebay) for $155.00. However, there was a note with the kit that indicated that the symptom on that particular model might have been simply a bad cable connection at the motor end of the cable. The wire lugs are crimped-on in the motor connector and could work loose - the motor jumps around quite a lot during spin start-up...
Jan 31, 2009 | Maytag SAV5710 Top Load Washer
LR code on Maytag MAH5500BWW washer
i think you better see this link, there is a bulletin issued regarding your problem.
here is the link...http://www.servicematters.com/maytag_library/docs/ITDL-0017-B.pdf
i hope that answers your problem.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
