Lg wd 10480tp my drier is not working - Washing Machines
  • Washing Mach... Master
  • 2,113 Answers
First thing... go and turn off the 30 amp double breaker in your electrical panel and then turn it back on. If all is ok then fine. If not then ask again
Posted on Oct 20, 2013
Testimonial: "sir still problem again drier is not working properly"
  • Hafiz majid
    Hafiz majid Oct 20, 2013
    can u giving answer
  • mikadot
    mikadot Oct 20, 2013
    The next thing it could be is the element. Unless i know that model intimately i won't know anymore unless i take it apart to do some tests
I have an LG WD-1457RD washer and dryer and it shrinks all of my clothes, Possibly Temperature problem?
Very few driers have temperature controls. The best way to stop this happening is to run it for less time. Take the clothes out when they are still very slightly damp. If you hang them up straight away, you will find that most wont need ironing. Some dryers allow you to set the amount of moisture in the clothes when they shutoff, but they generally are the most expensive ones.
May 16, 2016 | LG Washing Machines
My LG dryer says check filter but I've cleaned the wire filter and the lint that was trapped under the filter. It still says check filter. Is there another filter?
I relocated my drier and noticed the same light when I plugged it back in. The owner's manual states that the light comes on whenever the drier is turned on, to remind you to check the one and only lint screen.
Apr 17, 2011 | LG DLE5977 Electric Dryer
How to replace a filter drier on a lg lsc27931 frige. Frige not cooling. Tech said it was the filter drier
unless you have knowledge and lots of refrigeration tool and equipment you cannot do this yourself.
Feb 21, 2011 | LG LSC27931S Side by Side Refrigerator
I have a bush wd 1000 txve washer drier and the drier wont work keeps coming up with e13
Hello,the E-13 error code is a drain timeout code. This means the pump has run a certain amount of time without fully draining itself. This could be anything from a clogged drain line in your home to a clogged drain line in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Thanks
Jun 01, 2010 | Washing Machines
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Orange crayon melted all over the drum of drier and I cannot get it cleaned. Any suggests?
You now have hot melted wax coating EVERYTHING, I bet.
First, unplug your dryer, for safety.
Now take some turpentine or wd-40 and dampen a cloth with it.
Scrub, scrub away.
once it's clean(will take a LOT of elbow grease), you'll want to clean up the solvent.
A wash-cloth, dampened with soapy water, will do a pretty good job here.
Finally, leave the machine OPEN for a good solid day/night.
This lets any fumes remaining from the solvent escape.
this is important, if you don't want to blow up your dryer when you next start it up.
Jun 01, 2009 | Whirlpool Dryers
LG VRIZON WIRELESS LED SCREEN IS BROKEN IDROPPED MY PHONE IN SOME WATER IN NOW MY SCREEN IS BLACK
When the battery got wet, it short circuited. So what you need to do is take the battery out and put the battery and the phone in a bowl of rice overnight or for 7-8 hours. If it doesn't work after that, try leaving the phone (opened up) and the battery next to a running hair-drier for a few hours. But do not leave the hair-drier on when you're not home. Hope this helps!
May 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
